Home » Eclipse Projects » Advanced Scripting Environment (EASE) » Py4J Update site Problem
Py4J Update site Problem [message #1778826] Fri, 22 December 2017 08:00 Go to next message
Andreas Graf is currently offline Andreas GrafFriend
I am tryring to install the EASE PY4J integration, but P2 complains about the following:
3 (org.eclipse.ease.lang.python.py4j 0.5.0.I201708071353) requires 'bundle py4j-java [0.10.4,0.11.0)'
I can only find an old update site on the web with p4j-java 0.10.2, is there something newer available?
Andreas
Re: Py4J Update site Problem [message #1778921 is a reply to message #1778826] Sun, 24 December 2017 09:50 Go to previous messageGo to next message
Christian Pontesegger is currently offline Christian PonteseggerFriend
Are you trying to install from the p2 site? Our site has a reference to the required py4J update site which should resolve automatically. Still you could try to add following address to your update sites:
https://dl.bintray.com/py4j/py4j-eclipse/0.10.4
merry christmas
Re: Py4J Update site Problem [message #1778987 is a reply to message #1778921] Wed, 27 December 2017 17:51 Go to previous messageGo to next message
Hi Christian,
I tried with Oomph setup and this constellation somehow only finds an update site with 10.2.
Thanks for the link, I will try it.
Andreas
Re: Py4J Update site Problem [message #1779026 is a reply to message #1778987] Fri, 29 December 2017 08:12 Go to previous message
Oh, I thought you were talking about a 'classic' p2 install. I will check the Oomph setup after the holiday season
Previous Topic:py4-java for ease update site
Next Topic:Execute script programmatically and synchronous
Current Time: Fri Mar 24 00:28:30 GMT 2023
Powered by FUDForum. Page generated in 0.01890 seconds
