Home » Eclipse Projects » Jubula » Jubula 8.5, no main class in swing aut config(Jubula 8.5, no main class in aut config)
Jubula 8.5, no main class in swing aut config [message #1778802] Thu, 21 December 2017 15:38 Go to next message
Sergey Korzhevsky is currently offline Sergey KorzhevskyFriend
Hi All,
I'm trying to create config for swing application.
There were "Main Class Name" and "Classpath" options in Jubula 8.1 and 8.3, but i don't have them in 8.5.
What do i need to change to get this parameters back?
[Updated on: Thu, 21 December 2017 15:40]
Report message to a moderator
Re: Jubula 8.5, no main class in swing aut config [message #1779545 is a reply to message #1778802] Tue, 09 January 2018 13:31 Go to previous messageGo to next message
Marvin Mueller is currently offline Marvin MuellerFriend
The option for main class and classpath has been removed.
If you want to use them you have two options:
Either you create a platform dependent script (e.g. bash(linux) or bat(windows))
and have there something like this(e.g. for linux DVDTool ):
java -cp DVDTool.jar org.eclipse.jubula.examples.aut.dvdtool.DVDTool
or you do this in the JRE Arguments parts of the configuration Dialog.
best regards
Marvin Mueller
Re: Jubula 8.5, no main class in swing aut config [message #1779630 is a reply to message #1779545] Wed, 10 January 2018 12:35 Go to previous message
Hi Marvin,
Thank you very much for answer. I tried both versions: bat file and "JRE Arguments". In both cases application is started fine, but Jubula says "Starting AUT with ID:...". So, looks like it doesn't catch that aut has been already started fine.
Could you, please, suggest me what can be wrong?
Thanks.
Previous Topic:Jubula 8.5 can't catpute controls in Ubuntu 16.04
Next Topic:Problem with hidden Menus in MenuBar for JavaFX AUT
Current Time: Tue Aug 11 01:07:12 GMT 2020
Powered by FUDForum. Page generated in 0.02048 seconds
