Home » Modeling » Graphiti » Set selection to a connection decorator
Set selection to a connection decorator [message #1778782] Thu, 21 December 2017 11:40 Go to next message
Julia Jung is currently offline Julia JungFriend
Hello everybody,
i have a question regarding setting the selection programmatically to a connection decorator. I already searched the forum but had no luck.
My diagram shows some kind of path (startpoint -> first point -> second point -> last point). The points are connected via FreeFormConnection decorated with a text label.
I want to navigate through the diagram via keyboard and select the shapes in an order i specify programmatically. I hooked in via KeyHandler and this works fine for pictogram elements. So i managed to set the selection to the pictogram elements programmatically. Now i got stucked setting the selection to text label connection decorators. Is it even possible and if so, how?
Thanks in advance for your help.
Re: Set selection to a connection decorator [message #1778980 is a reply to message #1778782] Wed, 27 December 2017 14:05 Go to previous messageGo to next message
Michael Wenz is currently offline Michael WenzFriend
Julia,
can you be a bit more specific what your issue is when you try to select a decorator? One difference is that they are children of their connections and do not appear in the list of the normal shapes of the diagram (diagram holds its connections, each connection holds its decorators).
Michael
Re: Set selection to a connection decorator [message #1779449 is a reply to message #1778980] Mon, 08 January 2018 08:50 Go to previous messageGo to next message
Hello Michael,
thank you for your answer.
Well, i have a diagram like in the attached file.
The letters are placeholders that should be changed to numbers by the user.
Now i want to enable the user to navigate through the diagram via keyboard in an order i specify programmatically.
I wanted to solve that in the following way: when the user presses for example Enter on the keyboard, i check in the KeyHandler which element should be selected next (information is saved in the underlying model) and then set the selection to that element. A and C are PictogramElements on which i can set the selection via the selectPictogramElements-method. B is just a text label of a FreeFormConnection and i did not find a way to select this one via KeyHandler.
Julia
  • Attachment: diagram.png
    (Size: 2.67KB, Downloaded 83 times)
Re: Set selection to a connection decorator [message #1779598 is a reply to message #1779449] Wed, 10 January 2018 08:31 Go to previous message
Hello Julia,
not fully sure without digging deeper in the coding. But from what I know, the selectPictogramElements method uses a map from pictogram element to GEF object for the selection to happen. Probably the decorator shapes are not contained in that.
So this looks like a gap in Graphiti, either we should enhance the selectPictogramElements method to also allow decorators or offer a new method for selecting decorators. Would you please file an enhancement bug for that?
Michael
Previous Topic:How to set the order of shape?
Next Topic:How to modify the default behavior of draw connection?
Current Time: Wed Jan 27 13:08:57 GMT 2021
Powered by FUDForum. Page generated in 0.01832 seconds
