Re: GCC Linker [message #1778893 is a reply to message #1778736] |
Sat, 23 December 2017 06:26 |
David Vavra Messages: 1426 Registered: October 2012 |
Works in Oxygen and don't see why it wouldn't work in Luna as there should be no fundamental difference.
Make sure that you changed the current configuration (selected at the top of the dialog)
and also clean the project to force a new makefile to be generated.
You may need to delete the configuration directory to get a new makefile.
UPDATE: Tried it with NEON.3 in Windows linking a MinGW library and it worked.
g++ "-LC:\\Apps\\MinGW\\lib" -o Hello.exe Hello.o -lkernel32
[Updated on: Sat, 23 December 2017 06:37] Report message to a moderator
Re: GCC Linker [message #1779435 is a reply to message #1779186] |
Mon, 08 January 2018 00:27 |
The settings dialog allows you to specify which build configuration makefile you want to change.
Selecting All configurations means that the changes you subsequently make will apply to all configurations.
The keyword is subsequently.
You build by selecting a configuration to build from Project --> Build Configurations --> Set Active.
Your previous post showed you changed the configuration named Debug but built from the one named Release.
Your latest post is not showing which configuration is being built.
You omitted the line beginning **** Build of configuration
FUDForum. Page generated in 0.03892 seconds
