Home » Eclipse Projects » Eclipse Platform » Why is Oxygen so unstable?
Why is Oxygen so unstable? [message #1778564] Sun, 17 December 2017 22:04 Go to next message
Hernan Gonzalez is currently offline Hernan GonzalezFriend
I've been using Eclipse since practically its birth (I've even used Visual Age), and I don't recall a release more unstable than Oxygen. Terrible.
I love Eclipse and I appreciate the hard work of the developers. But I'd appreciate that,the development, instead of adding new features, were more focused in stability.
Today,I experienced 83 Exceptions in a few seconds, plus a popup telling me to close the IDE. Below comes the detail.
I post this here, because the https://dev.eclipse.org/recommenders/ site is currently worlking badly (server connection lost, trying to reconnect) and the bugtracker is even less friendly than the forums. If some developer considers that could help, he/she could create or update the issue in the bugtracker with the information that follows. If not, well, let it be a rant.
Here's the log. To avoid repetitions, Ive replaced the stack traces by some identificators:
SWT-4559-* are variations of :
at org.eclipse.swt.SWT.error(SWT.java:4559)
at org.eclipse.swt.widgets.Menu.getItems(Menu.java:881)
WIDGET-572 -* are variations of :
at org.eclipse.swt.widgets.Widget.getData(Widget.java:572)
at org.eclipse.epp.internal.mpc.ui.wizards.MarketplaceDropAdapter.findDropTarget(MarketplaceDropAdapter.java:158)
at org.eclipse.epp.internal.mpc.ui.wizards.MarketplaceDropAdapter.hookRecursive(MarketplaceDropAdapter.java:124)
SWT-error-4533-* are variations of
org.eclipse.swt.SWTException: Invalid thread access
at org.eclipse.swt.SWT.error(SWT.java:4533)
at org.eclipse.swt.SWT.error(SWT.java:4448)
at org.eclipse.swt.SWT.error(SWT.java:4419)
at org.eclipse.swt.widgets.Widget.error(Widget.java:482)
at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:373)
at org.eclipse.swt.widgets.MenuItem.setAccelerator(MenuItem.java:697)
at org.eclipse.jface.action.ActionContributionItem.update(ActionContributionItem.java:890)
at org.eclipse.jface.action.ActionContributionItem.lambda$0(ActionContributionItem.java:108)
at org.eclipse.jface.action.ExternalActionManager$CommandCallback.bindingManagerChanged(ExternalActionManager.java:270)
at org.eclipse.jface.bindings.BindingManager.fireBindingManagerChanged(BindingManager.java:899)
Here come the 83 errors:
Full detail is zip and attached
I'm using Eclipse 4.7.1a for RCP, 32 bits, Java 8, Windows 7
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:47:43.581
!MESSAGE Unhandled event loop exception
!STACK 0
org.eclipse.swt.SWTError: Cannot get count [GetLastError=0x0]
SWT-4559-A
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:20.893
!STACK 0
org.eclipse.swt.SWTError: Cannot get count [GetLastError=0x579]
SWT-4559-B
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:20.905
!MESSAGE Error occurred during status handling
!STACK 0
WIDGET-572-A
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:20.920
!STACK 0
WIDGET-572-B
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:20.940
!STACK 0
WIDGET-572-C
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:20.949
!STACK 0
WIDGET-572-D
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:20.960
!STACK 0
WIDGET-572-C
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:20.969
!STACK 0
WIDGET-572-D
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:20.978
!STACK 0
WIDGET-572-C
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:20.986
!STACK 0
WIDGET-572-D
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:20.995
!STACK 0
WIDGET-572-C
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.004
!STACK 0
WIDGET-572-D
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.013
!STACK 0
WIDGET-572-C
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.020
!STACK 0
WIDGET-572-D
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.028
!STACK 0
WIDGET-572-C
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.036
!STACK 0
WIDGET-572-D
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.046
!STACK 0
WIDGET-572-C
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.054
!STACK 0
WIDGET-572-D
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.063
!STACK 0
WIDGET-572-C
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.072
!STACK 0
WIDGET-572-D
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.080
!STACK 0
WIDGET-572-C
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.088
!STACK 0
WIDGET-572-D
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.097
!STACK 0
WIDGET-572-C
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.106
!STACK 0
WIDGET-572-D
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.114
!STACK 0
WIDGET-572-C
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.122
!STACK 0
WIDGET-572-D
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.131
!STACK 0
WIDGET-572-C
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.140
!STACK 0
WIDGET-572-D
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.149
!STACK 0
WIDGET-572-C
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.158
!STACK 0
WIDGET-572-D
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.167
!STACK 0
WIDGET-572-C
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.175
!STACK 0
WIDGET-572-D
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.184
!STACK 0
WIDGET-572-C
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.193
!STACK 0
WIDGET-572-D
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.202
!STACK 0
WIDGET-572-C
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.209
!STACK 0
WIDGET-572-D
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.218
!STACK 0
WIDGET-572-C
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.227
!STACK 0
WIDGET-572-D
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.235
!STACK 0
WIDGET-572-C
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.244
!STACK 0
WIDGET-572-D
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.251
!STACK 0
WIDGET-572-C
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.261
!STACK 0
WIDGET-572-D
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.269
!STACK 0
WIDGET-572-C
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.278
!STACK 0
WIDGET-572-D
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.287
!STACK 0
WIDGET-572-C
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.295
!STACK 0
WIDGET-572-D
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.304
!STACK 0
WIDGET-572-C
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.312
!STACK 0
WIDGET-572-D
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.321
!STACK 0
WIDGET-572-C
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.329
!STACK 0
WIDGET-572-D
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.338
!STACK 0
WIDGET-572-C
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.348
!STACK 0
WIDGET-572-D
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.356
!STACK 0
WIDGET-572-C
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.364
!STACK 0
WIDGET-572-D
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.373
!STACK 0
WIDGET-572-C
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.381
!STACK 0
WIDGET-572-D
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.388
!STACK 0
WIDGET-572-C
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.397
!STACK 0
WIDGET-572-D
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.406
!STACK 0
WIDGET-572-C
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.414
!STACK 0
WIDGET-572-D
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.422
!STACK 0
WIDGET-572-C
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.430
!STACK 0
WIDGET-572-D
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.439
!STACK 0
WIDGET-572-C
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.447
!STACK 0
WIDGET-572-D
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.455
!STACK 0
WIDGET-572-C
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.463
!STACK 0
WIDGET-572-D
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.471
!STACK 0
WIDGET-572-C
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.480
!STACK 0
WIDGET-572-D
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.488
!STACK 0
WIDGET-572-C
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.498
!STACK 0
WIDGET-572-D
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:21.505
!STACK 0
WIDGET-572-E
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:23.294
!STACK 0
WIDGET-572-C
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:23.302
!STACK 0
WIDGET-572-D
!ENTRY org.eclipse.equinox.event 4 0 2017-12-17 17:48:27.695
!MESSAGE Exception while dispatching event org.osgi.service.event.Event [topic=org/eclipse/e4/ui/model/ui/UIElement/widget/SET] {ChangedElement=org.eclipse.e4.ui.model.application.ui.basic.impl.TrimmedWindowImpl@cf5915 (elementId: IDEWindow, tags: [topLevel, shellMaximized], contributorURI: platform:/plugin/org.eclipse.platform) (widget: null, renderer: org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer@1ad658, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (label: %trimmedwindow.label.eclipseSDK, iconURI: null, tooltip: null, context: TrimmedWindowImpl (IDEWindow) Context, variables: [], x: -16, y: 0, width: 1024, height: 768), Widget=null, org.eclipse.e4.data={ChangedElement=org.eclipse.e4.ui.model.application.ui.basic.impl.TrimmedWindowImpl@cf5915 (elementId: IDEWindow, tags: [topLevel, shellMaximized], contributorURI: platform:/plugin/org.eclipse.platform) (widget: null, renderer: org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer@1ad658, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (label: %trimmedwindow.label.eclipseSDK, iconURI: null, tooltip: null, context: TrimmedWindowImpl (IDEWindow) Context, variables: [], x: -16, y: 0, width: 1024, height: 768), AttName=widget, EventType=SET, OldValue=Shell {workspace_dev4 - Eclipse}, Widget=null}, AttName=widget, EventType=SET, OldValue=Shell {workspace_dev4 - Eclipse}} to handler org.eclipse.e4.ui.services.internal.events.UIEventHandler@b42a84
!STACK 0
SWT-4559-C
!ENTRY org.eclipse.ui 4 0 2017-12-17 17:48:29.209
!STACK 0
SWT-4559-D
!ENTRY org.eclipse.osgi 4 0 2017-12-17 17:48:29.275
!MESSAGE Application error
!STACK 1
SWT-4559-E
!ENTRY org.eclipse.e4.ui.workbench 4 0 2017-12-17 17:48:29.942
!MESSAGE FrameworkEvent ERROR
!STACK 0
SWT-error-4533-A
!ENTRY org.eclipse.mylyn.monitor.ui 4 2 2017-12-17 17:48:31.340
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.mylyn.monitor.ui".
!STACK 0
SWT-error-4533-B
!ENTRY org.eclipse.mylyn.context.core 2 0 2017-12-17 17:48:31.350
!MESSAGE Activity monitor 'class org.eclipse.mylyn.internal.monitor.ui.WorkbenchUserActivityMonitor' was disabled due to a failure
!STACK 0
SWT-error-4533-B
!ENTRY org.eclipse.core.resources 2 10035 2017-12-17 17:48:31.424
!MESSAGE The workspace will exit with unsaved changes in this session.
!ENTRY org.eclipse.core.jobs 2 2 2017-12-17 17:48:31.805
!MESSAGE Job found still running after platform shutdown. Jobs should be canceled by the plugin that scheduled them during shutdown: org.eclipse.ui.internal.ide.IDEWorkbenchErrorHandler$1
!ENTRY org.eclipse.core.jobs 2 2 2017-12-17 17:48:31.814
!MESSAGE Job found still running after platform shutdown. Jobs should be canceled by the plugin that scheduled them during shutdown: org.eclipse.ui.internal.progress.TaskBarProgressManager$1
!ENTRY org.eclipse.core.jobs 2 2 2017-12-17 17:48:31.823
  • Attachment: oxygen.zip
    (Size: 7.11KB, Downloaded 189 times)
Re: Why is Oxygen so unstable? [message #1778565 is a reply to message #1778564] Sun, 17 December 2017 22:09 Go to previous messageGo to next message
Small correction:
WIDGET-572: are variations of one of these two:
at org.eclipse.egit.ui.internal.clone.GitCloneDropAdapter.findDropTarget(GitCloneDropAdapter.java:156)
at org.eclipse.egit.ui.internal.clone.GitCloneDropAdapter.hookRecursive(GitCloneDropAdapter.java:126)
Re: Why is Oxygen so unstable? [message #1778570 is a reply to message #1778565] Mon, 18 December 2017 03:20 Go to previous messageGo to next message
Dominic Cerisano is currently offline Dominic CerisanoFriend
The problem is likely related to the fact you are using a 32 bit version of Windows 7, which has exited mainstream support. Eclipse cannot be held responsible for newer JVMs that are not fully supported on older OSes. I would be willing to bet your problems occurred when you updated Java, not Eclipse.
If that is upsetting, then you should think about developing on Linux. I am running Eclipse Oxygen on the LTS version of Ubuntu (16.04) and it is rock stable, even on the latest Ryzen architectures. So exciting.
Just a warning that the latest Ubuntu 17 is not yet LTS and should not be used for development purposes due to stability issues (in my experience).
[Updated on: Mon, 18 December 2017 03:28]
Report message to a moderator
Re: Why is Oxygen so unstable? [message #1781952 is a reply to message #1778564] Thu, 15 February 2018 05:38 Go to previous messageGo to next message
Roy Epperson is currently offline Roy EppersonFriend
Have to second the comment regarding Oxygen 4.7.2 on Ubuntu 17.10. Up until
the past several days, things were okay. The Oxygen screen would start disappearing off to the right of the display. Solved by re-starting Oxygen.
For the past couple of days projects in the workspace would not compile, editors would hang, mouse would move but no keyboard typing.
Today compiling a class referencing a java resource was working but now it creates a URI to a class's resource that is not even loaded in the Oxygen workspace...
I really don't want to have to go back OS versions but....
Re: Why is Oxygen so unstable? [message #1782518 is a reply to message #1781952] Sun, 25 February 2018 12:39 Go to previous message
Ilya Basin is currently offline Ilya BasinFriend
This is something... 12 days ago I installed 4.7.2 j2ee amd64 on Win7. Problems started with the Eclipse web installer blocked by some old files in Appdata. Then all sorts of problems, like unable to undo changes or format code in editor. The error popup asking to report the various errors. There just too many to even bother reporting. This version should've never been released.
Previous Topic:Regarding clickable labels in eclipse plugin
Next Topic:Contributing to the Platform/UI fails with missing org.apache.batik.i18n
Current Time: Sun Jan 19 16:43:15 GMT 2025
Powered by FUDForum. Page generated in 0.03606 seconds
