Re: Multiple models referenced by a same representation file [message #1778640 is a reply to message #1778543] |
Tue, 19 December 2017 08:59 |
Hi Eric,
The "New representation file" wizard allows you to init a Sirius session on one semantic resource, then you can add additional resources as semantic resources of your session thanks to the "Add model" menu on the .aird file : it will show you a wizard with two choices: create a new model file or reference an existing one.
Note that the recommended way would be to create a Modeling Project (with the corresponding wizard) and then create or put you semantic resources in it (it will detect, load and add EMF models as semantic resource of the project's representations file). You can also use the "Configure > Add the Modeling Project nature" menu on the project to convert your project into a modeling project.
Maxime
Maxime Porhel - Obeo
FUDForum. Page generated in 0.03045 seconds
