Home » Eclipse Projects » Kura » How to connect Kura gateway to Hono
How to connect Kura gateway to Hono [message #1778416] Thu, 14 December 2017 06:05 Go to next message
fatih ayvaz is currently offline fatih ayvazFriend
I am trying to connect my Kura gateway on Rasperry PI to the Hono. However, I could not do that. As far as I see from Hono documentation, it is possible to connect any gateway via protocol adapters which are linked to QPID dispatch router. However, as far as I know, Kura can communicate with MQTT broker directly at the cloud side.
Appreciate if anybody could help me.
thanks,
-fatih
Re: How to connect Kura gateway to Hono [message #1778447 is a reply to message #1778416] Thu, 14 December 2017 10:21 Go to previous messageGo to next message
Benjamin Cabé is currently offline Benjamin CabéFriend
Did you look at https://www.eclipse.org/hono/user-guide/kura-adapter/ ?
If you need additional help, I believe reaching out to the Hono folks on their mailing list will be helpful - https://accounts.eclipse.org/mailing-list/hono-dev
Re: How to connect Kura gateway to Hono [message #1778458 is a reply to message #1778447] Thu, 14 December 2017 13:40 Go to previous messageGo to next message
Many thanks Benjamin for your quick help.
Re: How to connect Kura gateway to Hono [message #1793541 is a reply to message #1778458] Thu, 09 August 2018 18:41 Go to previous messageGo to next message
Mohab Aly is currently offline Mohab AlyFriend
Reviving this thread again, please!
I am not able to connect Kura (on Raspberry Pi) to Hono (on local machine). I tried the port-forwarding option, but unfortunately, it is not working. There is a bug related to that (please see [1]).
The related documentation provided by @Benjamin, is not helping a lot on this matter!
@fatih, were you able to connect both of them together? Could you please share the guidelines to have such connection done?
On a side note: I have opened a ticket with Hono (Github) [2], where finally I was told about the bug!
[1] https://github.com/kubernetes/kubernetes/pull/46517
[2] https://github.com/eclipse/hono/issues/763
[Updated on: Fri, 10 August 2018 15:37]
Report message to a moderator
Re: How to connect Kura gateway to Hono [message #1793542 is a reply to message #1778458] Thu, 09 August 2018 18:42 Go to previous message
[Updated on: Fri, 10 August 2018 15:38]
Previous Topic:cellular connectivity
Next Topic:How to connect Kura gateway to Hono
Current Time: Sat Jul 24 21:59:14 GMT 2021
Powered by FUDForum. Page generated in 0.01899 seconds
