Home » Eclipse Projects » Jubula » foreground window change - ub_ Tbc_checkExistenceOfTab_byValueOrString
foreground window change - ub_ Tbc_checkExistenceOfTab_byValueOrString [message #1778334] Wed, 13 December 2017 09:00 Go to next message
Thomas Kowalski is currently offline Thomas KowalskiFriend
Hello
I'm testing with exits [Boolean]: false, after the test the window is switched. Can the current window be kept in the foreground, or how do I get Windows back to the foreground?
thx
[Updated on: Wed, 13 December 2017 09:07]
Report message to a moderator
Re: foreground window change - ub_ Tbc_checkExistenceOfTab_byValueOrString [message #1778399 is a reply to message #1778334] Wed, 13 December 2017 19:59 Go to previous message
Milos Hroudny is currently offline Milos HroudnyFriend
you can use AutoIt to solve the situation. Compile the AutoIt script
Opt("WinTitleMatchMode",2)
WinActivate($CmdLine[1])
You can name the script WinActivate.au3 and after compile you get
WinActivate.exe. Call this external command with one parameter
containing the string from window titlebar and your application will be on the top.
Best Regards
Milos
Previous Topic:execute linux command from jubula
Next Topic:Jubula Christmas Time
Current Time: Fri Jul 03 17:53:05 GMT 2020
Powered by FUDForum. Page generated in 0.01912 seconds
