Home » Modeling » Papyrus » Contextual menu according to Stereotype of the selected element
Contextual menu according to Stereotype of the selected element [message #1778288] Tue, 12 December 2017 16:28 Go to next message
Yoann Farre is currently offline Yoann FarreFriend
I would create a contextual menu according to the Stereotype applied on an element. This menu will be used to execute some actions which are not the creation of new elements in the model.
I know how to create a such contextual menu using handlers and commands on a UML::Package or UML::Class for example but I don't know how to extend this principle to the stereotypes.
Is it possible? And how could I do that?
Thank you for reading!
Yoann.
Re: Contextual menu according to Stereotype of the selected element [message #1778291 is a reply to message #1778288] Tue, 12 December 2017 16:48 Go to previous messageGo to next message
Camille Letavernier is currently offline Camille LetavernierFriend
Hi Yoann,
It is absolutely possible, although default Eclipse Property Testers may not be sufficient to specify your "visibleWhen" expression. Also, I don't think that Papyrus provides this Property Test either, so you may need to implement your own.
You need to:
  • Contribute (and implement) a new IPropertyTester, via the org.eclipse.core.expressions.propertyTesters extension point:
    • In the property tester code, find the selected UML Element (Using org.eclipse.papyrus.uml.tools.utils.UMLUtil.resolveUMLElement(Object) may help you to retrieve an EObject from a selected Tree Element or Diagram part)
    • Once you have the selected UML Element, iterate over its applied stereotypes (Via Element#getAppliedStereotype(String), or Element#getAppliedStereotypes(), or Element#getStereotypeApplications(), ...)
    • If you find your stereotype, then return true
  • Then, you can reference this property tester from your Eclipse UI Command/Menu/Handler visibleWhen/activeWhen/enableWhen expressions, as usual
HTH,
Camille
Camille Letavernier
Re: Contextual menu according to Stereotype of the selected element [message #1778323 is a reply to message #1778291] Wed, 13 December 2017 07:40 Go to previous messageGo to next message
Hi Camille,
Thank you! This is really helpful. I will try to implement this solution!
Yoann.
Re: Contextual menu according to Stereotype of the selected element [message #1778428 is a reply to message #1778288] Thu, 14 December 2017 08:29 Go to previous message
If someone is interested by a such feature, this is the code of the tester I use (working code).
public class StereotypeTester extends PropertyTester {
	 * id for the property to test
	public static final String STEREOTYPE_ID = "stereotype"; //$NON-NLS-1$
	 * @see org.eclipse.core.expressions.IPropertyTester#test(java.lang.Object,
	 *      java.lang.String, java.lang.Object[], java.lang.Object)
	 * @param receiver
	 * @param property
	 * @param args
	 * @param expectedValue
	 * @return
	public boolean test(Object receiver, String property, Object[] args, Object expectedValue) {
		if (STEREOTYPE_ID.equals(property) && receiver instanceof IStructuredSelection) {
			Object object = ((IStructuredSelection) receiver).getFirstElement();
			EObject eObject = UMLUtil.resolveUMLElement(object);
			if (eObject instanceof Element) {
				return testStereotype((Element) eObject, expectedValue);
		return false;
	 * Test the stereotype
	 * @param element
	 *            the current element
	 *            the expected value : the wanted stereotype
	 * @return <code>true</code> if the current element has the wanted stereotype
	 *         applied
	private boolean testStereotype(Element element, Object expectedValue) {
		EList<Stereotype> stereotypeList = element.getAppliedStereotypes();
		for (Stereotype stereotype : stereotypeList) {
			if (expectedValue.equals(stereotype.getQualifiedName())) {
				return true;
		return false;
Previous Topic:Papyrus Neon (2.0.X) RCP
Next Topic:Persistence of StereotypeShapes
Current Time: Mon Feb 24 09:21:48 GMT 2020
Powered by FUDForum. Page generated in 0.02652 seconds
