Home » Eclipse Projects » NatTable » why column header can not fully copied(can not fully copy nattable's column header)
why column header can not fully copied [message #1778264] Tue, 12 December 2017 12:31 Go to next message
chun liang Wen is currently offline chun liang WenFriend
 CopyDataCommandHandler copyHandler = new CopyDataCommandHandler(selectionLayer, columnHeaderDataLayer, rowHeaderDataLayer);
        natTable.registerCommandHandler(copyHandler);
        natTable.doCommand(new CopyDataToClipboardCommand("\t", //$NON-NLS-1$
                System.getProperty("line.separator"), //$NON-NLS-1$
                natTable.getConfigRegistry()));
if selectionLayer.selectAll() , all of row data can be copied. but only part of column header copied. How to fix this? Is this a defect of nattable?
Re: why column header can not fully copied [message #1778319 is a reply to message #1778264] Wed, 13 December 2017 06:03 Go to previous messageGo to next message
Dirk Fauth is currently offline Dirk FauthFriend
If I look at our _751_CopyExample this is working pretty good. Even if I make the window smaller to enable scrolling.
So without additional information I can't say anything as the given information is too abstract.
Please note that a simple "it does not work, how can I fix this or is this a bug" without saying explicitly what is not working by giving an example with some more code related to your composition is not enough!
Re: why column header can not fully copied [message #1778653 is a reply to message #1778319] Tue, 19 December 2017 11:03 Go to previous message
The root cause is that second parameter passed should be a DataLayer named as columnHeaderDataLayer, but be wrongly written as a ColumnHeaderLayer which named as columnHeaderLayer.
Thanks for you reply.
[Updated on: Tue, 19 December 2017 11:05]
Report message to a moderator
Previous Topic:handle page up/down events in nattable
Next Topic:Is that possible select a cell in a FixedSummaryRowLayer and copy it?
Current Time: Sun Aug 18 19:43:48 GMT 2019
Powered by FUDForum. Page generated in 0.01667 seconds
