Crashing on closing [message #1778025] |
Fri, 08 December 2017 09:49 |
RS I Messages: 3 Registered: December 2017 |
I just installed Eclipse for web development, but every time I close the IDE it crashes. Excerpts from the returned errors:
# A fatal error has been detected by the Java Runtime Environment:
# SIGSEGV (0xb) at pc=0x00007f132db7f44d, pid=16703, tid=16713
# JRE version: OpenJDK Runtime Environment (9.0+181) (build 9+181)
# Java VM: OpenJDK 64-Bit Server VM (9+181, mixed mode, tiered, compressed oops, g1 gc, linux-amd64)
# Problematic frame:
# C [libjavascriptcoregtk-4.0.so.18+0xe3144d] WTFCrash+0x1d
(Eclipse:19088): GLib-CRITICAL **: g_base64_encode_step: assertion 'in != NULL' failed
WARNING: An illegal reflective access operation has occurred
Is there a workaround for this? If not, will somebody tell me how I uninstall Eclipse (I don't want to waste space on the Linux partition). I understand that all I have to do is to delete the Eclipse folders. Right now I know about: eclipse-installer, javascript-latest-released and .p2. But I'm not sure if I should delete .p2 too. Should I? Beside those folders is there another one I should know of?
Thanks!
FUDForum. Page generated in 0.08196 seconds
