Home » Modeling » Papyrus » Weird profile references when using the "New Papyrus Model" wizard
Weird profile references when using the "New Papyrus Model" wizard [message #1777738] Sun, 03 December 2017 22:02 Go to next message
Davide Rossi is currently offline Davide RossiFriend
When applying "local" profiles (with "browse workspace") you get two different reference types for the applied profile if you apply it after creating the model or if you apply it from the "New Papyrus Model" wizard (in the last page).
In the first case you get relative references like "path/foo.profile.uml" in the second case you get a schema-less absolute paths: "/<project dir>/path/foo.profile.uml".
While both references work from inside Eclipse if you deal with the second type from a stand-alone program you are in troubles.
Is that by design or is that a bug?
Re: Weird profile references when using the "New Papyrus Model" wizard [message #1777747 is a reply to message #1777738] Mon, 04 December 2017 07:36 Go to previous message
It was agreed on the UML newsgroup that this is probably a Papyrus bug.
Please raise a Bugzilla with a repro.
Ed Willink
Previous Topic:How to copy only a part of a template model
Next Topic:Viewpoint configuration question in Neon.3
Current Time: Mon Feb 24 09:22:15 GMT 2020
Powered by FUDForum. Page generated in 0.05601 seconds
