Migrating content assist tests to Xpect possible? [message #1777704] |
Fri, 01 December 2017 18:48 |
Axel Guckelsberger Messages: 354 Registered: July 2009 |
I am currently migrating several tests to Xpect, but fail with the content assist.
These work fine if I use something like:
@RunWith(XtextRunner)
@InjectWith(MyDslUiInjectorProvider)
class SimpleContentAssistTest extends AbstractContentAssistTest {
@Test
def void testSomething() {
newBuilder
.assertCount(123)
.assertText('foo', 'bar')
Now I tried to achieve the same with Xpect, inspired by https://github.com/eclipse/Xpect/issues/79 which references an (obsolete) example.
Here is what I have at the moment:
@RunWith(XpectRunner)
@XpectImport(#[XtextStandaloneSetup, XtextWorkspaceSetup])
@XpectTestFiles(relativeTo = FileRoot.PROJECT, baseDir = "model/testcases/contentassist", fileExtensions="xt")
class MyDslContentAssistTest extends AbstractContentAssistTest {
@ParameterParser(syntax = "('at' arg2=OFFSET)?")
@Xpect
def void proposedElements(
@CommaSeparatedValuesExpectation ICommaSeparatedValuesExpectation expectation,
@ThisResource XtextResource resource,
int offset
) throws Exception {
setUp
val content = resource.parseResult.rootNode.text
val fixture = newBuilder.append(content)
val proposals = fixture.computeCompletionProposals(offset).toList.map[displayString]
expectation.assertEquals(proposals)
tearDown
The setUp and tearDown calls are due to https://github.com/eclipse/Xpect/issues/204
The tests result in exceptions like:
!ENTRY org.apache.log4j 4 0 2017-12-01 19:42:29.876
!MESSAGE org.eclipse.xtext.ide.editor.contentassist.antlr.ContentAssistContextFactory - java.lang.NullPointerException
!STACK 0
java.util.concurrent.ExecutionException: java.lang.NullPointerException
at java.util.concurrent.FutureTask.report(FutureTask.java:122)
at java.util.concurrent.FutureTask.get(FutureTask.java:192)
at org.eclipse.xtext.ide.editor.contentassist.antlr.ContentAssistContextFactory.doCreateContexts(ContentAssistContextFactory.java:180)
at org.eclipse.xtext.ide.editor.contentassist.antlr.ContentAssistContextFactory.create(ContentAssistContextFactory.java:130)
at org.eclipse.xtext.ui.editor.contentassist.antlr.DelegatingContentAssistContextFactory$StatefulFactory.doCreateContexts(DelegatingContentAssistContextFactory.java:92)
at org.eclipse.xtext.ui.editor.contentassist.antlr.DelegatingContentAssistContextFactory$StatefulFactory.create(DelegatingContentAssistContextFactory.java:78)
at org.eclipse.xtext.ui.editor.contentassist.antlr.DelegatingContentAssistContextFactory.create(DelegatingContentAssistContextFactory.java:55)
at org.eclipse.xtext.ui.editor.contentassist.CompletionProposalComputer.createContentAssistContexts(CompletionProposalComputer.java:67)
at org.eclipse.xtext.ui.editor.contentassist.CompletionProposalComputer.exec(CompletionProposalComputer.java:49)
at org.eclipse.xtext.ui.editor.contentassist.CompletionProposalComputer.exec(CompletionProposalComputer.java:1)
at org.eclipse.xtext.resource.OutdatedStateManager.exec(OutdatedStateManager.java:91)
at org.eclipse.xtext.ui.editor.model.XtextDocument$XtextDocumentLocker.internalReadOnly(XtextDocument.java:520)
at org.eclipse.xtext.ui.editor.model.XtextDocument$XtextDocumentLocker.priorityReadOnly(XtextDocument.java:485)
at org.eclipse.xtext.ui.editor.model.XtextDocument.priorityReadOnly(XtextDocument.java:142)
at org.eclipse.xtext.ui.editor.contentassist.XtextContentAssistProcessor.computeCompletionProposals(XtextContentAssistProcessor.java:69)
at org.eclipse.xtext.ui.testing.ContentAssistProcessorTestBuilder.computeCompletionProposals(ContentAssistProcessorTestBuilder.java:509)
at org.eclipse.xtext.ui.testing.ContentAssistProcessorTestBuilder.computeCompletionProposals(ContentAssistProcessorTestBuilder.java:500)
at org.eclipse.xtext.ui.testing.ContentAssistProcessorTestBuilder.computeCompletionProposals(ContentAssistProcessorTestBuilder.java:490)
at org.eclipse.xtext.ui.testing.ContentAssistProcessorTestBuilder.computeCompletionProposals(ContentAssistProcessorTestBuilder.java:478)
at org.eclipse.xtext.ui.testing.ContentAssistProcessorTestBuilder.computeCompletionProposals(ContentAssistProcessorTestBuilder.java:559)
at org.example.mydsl.ui.tests.contentassist.MyDslContentAssistTest.proposedElements(MyDslContentAssistTest.java:44)
at org.xpect.runner.TestExecutor.runTest(TestExecutor.java:150)
at org.xpect.runner.XpectTestRunner.runInternal(XpectTestRunner.java:67)
at org.xpect.runner.AbstractTestRunner.run(AbstractTestRunner.java:59)
at org.xpect.runner.XpectFileRunner.run(XpectFileRunner.java:142)
at org.xpect.runner.XpectRunner.runChild(XpectRunner.java:208)
at org.xpect.runner.XpectRunner.runChild(XpectRunner.java:1)
at org.junit.runners.ParentRunner$3.run(ParentRunner.java:290)
at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:71)
at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:288)
at org.junit.runners.ParentRunner.access$000(ParentRunner.java:58)
at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:268)
at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:26)
at org.junit.internal.runners.statements.RunAfters.evaluate(RunAfters.java:27)
at org.junit.runners.ParentRunner.run(ParentRunner.java:363)
at org.xpect.runner.XpectRunner.run(XpectRunner.java:194)
at org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.run(JUnit4TestReference.java:86)
at org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.java:38)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:539)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:761)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:461)
at org.eclipse.pde.internal.junit.runtime.RemotePluginTestRunner.main(RemotePluginTestRunner.java:181)
at org.eclipse.pde.internal.junit.runtime.PlatformUITestHarness.lambda$0(PlatformUITestHarness.java:43)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:37)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:182)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4497)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:4110)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1150)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1039)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:153)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:680)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:594)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:151)
at org.eclipse.pde.internal.junit.runtime.NonUIThreadTestApplication.runApp(NonUIThreadTestApplication.java:52)
at org.eclipse.pde.internal.junit.runtime.UITestApplication.runApp(UITestApplication.java:43)
at org.eclipse.pde.internal.junit.runtime.NonUIThreadTestApplication.start(NonUIThreadTestApplication.java:46)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:653)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:590)
at org.eclipse.equinox.launcher.Main.run(Main.java:1499)
at org.eclipse.equinox.launcher.Main.main(Main.java:1472)
at com.google.common.base.Preconditions.checkNotNull(Preconditions.java:770)
at org.eclipse.xtext.ide.editor.contentassist.antlr.AbstractContentAssistParser.getFollowElements(AbstractContentAssistParser.java:342)
at org.eclipse.xtext.ide.editor.contentassist.antlr.AbstractContentAssistParser.getFollowElements(AbstractContentAssistParser.java:337)
at org.eclipse.xtext.ide.editor.contentassist.antlr.AbstractContentAssistParser.getFollowElements(AbstractContentAssistParser.java:331)
at org.eclipse.xtext.ide.editor.contentassist.antlr.AbstractContentAssistParser.getFollowElements(AbstractContentAssistParser.java:381)
at org.eclipse.xtext.ide.editor.contentassist.antlr.ContentAssistContextFactory.handleLastCompleteNodeIsAtEndOfDatatypeNode(ContentAssistContextFactory.java:229)
at org.eclipse.xtext.ide.editor.contentassist.antlr.ContentAssistContextFactory$2.call(ContentAssistContextFactory.java:160)
at org.eclipse.xtext.ide.editor.contentassist.antlr.ContentAssistContextFactory$2.call(ContentAssistContextFactory.java:157)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
Am I doing something obviously wrong? Or should I just avoid using Xpect for that?
Interestingly testing the outline view using Xpect works like a charm. So I thought it should be possible for other subclasses of AbstractEditorTest, too.
[Updated on: Sun, 03 December 2017 17:30] Report message to a moderator
FUDForum. Page generated in 0.03594 seconds
