Resource.load error: ">" is not legal [message #1777500] |
Wed, 29 November 2017 17:41 |
Sina Madani Messages: 160 Registered: November 2015 Location: York, UK |
So I have the MoDisco Java metamodel and some test model file. When I load this, I get the following stack trace:
org.eclipse.emf.ecore.resource.Resource$IOWrappedException: Value '>' is not legal. (file:///D:/GDrive/PhD/Experiments/org.eclipse.ocl.examples.project.oclinecoretutorial/src/javaMM/launch/test.xmi, 1106, 119)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.handleErrors(XMLLoadImpl.java:77)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:185)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:261)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1518)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1297)
at org.eclipse.epsilon.evl.engine.test.acceptance.equivalence.StandaloneOCL.run(StandaloneOCL.java:187)
at javaMM.launch.JavaMMLauncher.main(JavaMMLauncher.java:25)
Caused by: org.eclipse.emf.ecore.xmi.IllegalValueException: Value '>' is not legal. (file:///D:/GDrive/PhD/Experiments/org.eclipse.ocl.examples.project.oclinecoretutorial/src/javaMM/launch/test.xmi, 1106, 119)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XMLHandler.java:2697)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.setAttribValue(XMLHandler.java:2751)
at org.eclipse.emf.ecore.xmi.impl.SAXXMIHandler.handleObjectAttribs(SAXXMIHandler.java:79)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromFactory(XMLHandler.java:2229)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromTypeName(XMLHandler.java:2132)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObject(XMLHandler.java:2067)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.createObject(XMIHandler.java:151)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleFeature(XMLHandler.java:1876)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XMLHandler.java:1030)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMIHandler.java:82)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:1008)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:719)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement(XMIHandler.java:190)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.startElement(AbstractSAXParser.java:509)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanStartElement(XMLDocumentFragmentScannerImpl.java:1359)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(XMLDocumentFragmentScannerImpl.java:2784)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:602)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:505)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:841)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:770)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:141)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1213)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:643)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl.parse(SAXParserImpl.java:327)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:175)
... 5 more
Caused by: java.lang.IllegalArgumentException: The value '>' is not a valid enumerator of 'InfixExpressionKind'
at org.eclipse.emf.ecore.impl.EFactoryImpl.createFromString(EFactoryImpl.java:307)
at org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.createFromString(XMLHelperImpl.java:1615)
at org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.setValue(XMLHelperImpl.java:1156)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XMLHandler.java:2692)
... 29 more
But the thing is, I've loaded this file before and it works in another context, but not this one. I'm trying to figure out the cause of the error and I'm certain it's nothing to do with the XML file (I looked at the text and it's simply a character inside a string, not an invalid XML file). So what could be causing this behaviour?
Thanks.
Re: Resource.load error: ">" is not legal [message #1777765 is a reply to message #1777665] |
Mon, 04 December 2017 12:08 |
Hi Ed,
Thanks for the reply. Bug 382956 certainly seems the cause of the issue, since I noticed that when opening the java_findbugs.ecore file with the OCLinEcore editor, the enum literals are not there; only names and numbers. I tried generating another Java model from the generated OCL code and re-running the program. Again I got an error that '+' is not legal. However when I opened the original java.ecore (without any embedded OCL) I see the literals are there, but when opening java_findbugs.ecore I see that the literal value is the same as the name. So, I made a copy of the original metamodel (java.ecore), opened that with OCLinEcore editor, copy-pasted the contents of the java_findbugs.ecore as shown in OCLinEcore editor and saved. Even without running the program, opening this with the sample Ecore editor shows that the EEnum literals have been replaced by the names instead.
Re: Resource.load error: ">" is not legal [message #1777896 is a reply to message #1777877] |
Tue, 05 December 2017 17:24 |
Hi Ed,
Thanks for the clarification. It seems the zip file you linked earlier wasn't the right one - the new one has done the trick! Once again thank you very much for your persistence and help regarding this issue.
Best Wishes,
Sina Madani
FUDForum. Page generated in 0.04244 seconds
