Home » Eclipse Projects » NatTable » Cell boundary of underlying cell showing when selecting a spanned cell
Cell boundary of underlying cell showing when selecting a spanned cell [message #1777361] Tue, 28 November 2017 20:40 Go to next message
Louis Detweiler is currently offline Louis DetweilerFriend
Member
index.php/fa/31417/0/
When clicking on a spanned cell, the boundary of the underlying cell that was clicked on shows through the spanned cell. Is there a way around this?
Thanks.
Re: Cell boundary of underlying cell showing when selecting a spanned cell [message #1777379 is a reply to message #1777361] Wed, 29 November 2017 04:51 Go to previous messageGo to next message
Dirk Fauth is currently offline Dirk FauthFriend
I can't tell you what is wrong with your configuration, but that should definitely not be. What you see is the selection anchor that is rendered by the SelectionLayerPainter. And in my compositions that use spanning it is rendered correctly. Do you use custom configured layer painter?
Re: Cell boundary of underlying cell showing when selecting a spanned cell [message #1777501 is a reply to message #1777379] Wed, 29 November 2017 17:45 Go to previous messageGo to next message
Member
No I don't. I think I may have figured it out. Should the getCellByPosition method in the spanning data provider return a cell at the origin column and row position spanned across the entire cell for every cell that gets covered by the span? Currently in my implementation it only does so for the origin cell.
Re: Cell boundary of underlying cell showing when selecting a spanned cell [message #1777502 is a reply to message #1777501] Wed, 29 November 2017 17:56 Go to previous message
For every cell in the span
Previous Topic:Row spanning in the row header region
Next Topic:Row selection with spanning
Current Time: Fri Dec 06 15:10:06 GMT 2019
Powered by FUDForum. Page generated in 0.06335 seconds
