Azure IoT Hub SSL Certificate [message #1777313] |
Tue, 28 November 2017 11:12 |
giuseppe ferro Messages: 34 Registered: August 2016 |
Member |
I have some problems to configure SSL Certificate in Kura 3.1.0.
I've follwed this
https://eclipse.github.io/kura/cloud/kura-azure.html
after configuring in all parts "Kura Cloud Stack for Azure IoT Hub"
in kura.log i have this:
2017-11-28 10:44:37,119 [DataServiceImpl:ReconnectTask] INFO o.e.k.c.d.t.m.MqttDataTransport - Creating a new client instance
2017-11-28 10:44:37,121 [DataServiceImpl:ReconnectTask] INFO o.e.k.c.d.t.m.MqttDataTransport - Using memory persistence for in-flight messages
2017-11-28 10:44:37,126 [DataServiceImpl:ReconnectTask] INFO o.e.k.c.d.t.m.MqttDataTransport - # ------------------------------------------------------------
2017-11-28 10:44:37,129 [DataServiceImpl:ReconnectTask] INFO o.e.k.c.d.t.m.MqttDataTransport - # Connection Properties
2017-11-28 10:44:37,131 [DataServiceImpl:ReconnectTask] INFO o.e.k.c.d.t.m.MqttDataTransport - # broker = ssl://*****.azure-devices.net:8883
2017-11-28 10:44:37,134 [DataServiceImpl:ReconnectTask] INFO o.e.k.c.d.t.m.MqttDataTransport - # clientId = airsense2
2017-11-28 10:44:37,138 [DataServiceImpl:ReconnectTask] INFO o.e.k.c.d.t.m.MqttDataTransport - # username = ****.azure-devices.net/****/api-version=2016-11-14
2017-11-28 10:44:37,140 [DataServiceImpl:ReconnectTask] INFO o.e.k.c.d.t.m.MqttDataTransport - # password = XXXXXXXXXXXXXX
2017-11-28 10:44:37,143 [DataServiceImpl:ReconnectTask] INFO o.e.k.c.d.t.m.MqttDataTransport - # keepAlive = 30
2017-11-28 10:44:37,146 [DataServiceImpl:ReconnectTask] INFO o.e.k.c.d.t.m.MqttDataTransport - # timeout = 20
2017-11-28 10:44:37,150 [DataServiceImpl:ReconnectTask] INFO o.e.k.c.d.t.m.MqttDataTransport - # cleanSession = true
2017-11-28 10:44:37,153 [DataServiceImpl:ReconnectTask] INFO o.e.k.c.d.t.m.MqttDataTransport - # MQTT version = 3.1.1
2017-11-28 10:44:37,156 [DataServiceImpl:ReconnectTask] INFO o.e.k.c.d.t.m.MqttDataTransport - # willDestination = $EDC/devices/****/MQTT/LWT
2017-11-28 10:44:37,159 [DataServiceImpl:ReconnectTask] INFO o.e.k.c.d.t.m.MqttDataTransport - # willMessage =
2017-11-28 10:44:37,161 [DataServiceImpl:ReconnectTask] INFO o.e.k.c.d.t.m.MqttDataTransport - #
2017-11-28 10:44:37,164 [DataServiceImpl:ReconnectTask] INFO o.e.k.c.d.t.m.MqttDataTransport - # Connecting...
2017-11-28 10:44:37,167 [pool-9-thread-1] INFO o.e.k.c.s.r.LogStatusRunnable - Notification LED off
2017-11-28 10:44:37,170 [pool-9-thread-1] INFO o.e.k.c.s.r.LogStatusRunnable - Notification LED fast blinking
2017-11-28 10:44:37,278 [MQTT Con: ****] INFO o.e.k.c.s.SSLSocketFactoryWrapper - SSL Endpoint Identification enabled.
2017-11-28 10:44:37,754 [DataServiceImpl:ReconnectTask] WARN o.e.k.c.d.t.m.MqttDataTransport - xxxxx Connect failed. Forcing disconnect. xxxxx {}
Not authorized to connect (5)
at org.eclipse.paho.client.mqttv3.internal.ExceptionHelper.createMqttException(ExceptionHelper.java:28)
at org.eclipse.paho.client.mqttv3.internal.ClientState.notifyReceivedAck(ClientState.java:990)
at org.eclipse.paho.client.mqttv3.internal.CommsReceiver.run(CommsReceiver.java:118)
at java.lang.Thread.run(Thread.java:745)
2017-11-28 10:44:37,758 [DataServiceImpl:ReconnectTask] INFO o.e.k.c.d.t.m.MqttDataTransport - Closing client...
2017-11-28 10:44:37,762 [DataServiceImpl:ReconnectTask] INFO o.e.k.c.d.t.m.MqttDataTransport - Closed
2017-11-28 10:44:37,765 [pool-9-thread-1] INFO o.e.k.c.s.r.LogStatusRunnable - Notification LED off
2017-11-28 10:44:37,768 [pool-9-thread-1] INFO o.e.k.c.s.r.LogStatusRunnable - Notification LED slow blinking
2017-11-28 10:44:37,772 [DataServiceImpl:ReconnectTask] WARN o.e.k.c.d.DataServiceImpl - Connect failed
org.eclipse.kura.KuraConnectException: "Connection failed. Cannot connect"
at org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport.connect(MqttDataTransport.java:333)
at org.eclipse.kura.core.data.DataServiceImpl$2.run(DataServiceImpl.java:609)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
Caused by: Not authorized to connect (5)
... 1 more
then i execute "openssl s_client -connect ***.azure-devices.net:8883"
for generate SSL CERTIFICATE.
The result is the SSL certificate chain. Copy all the certificates in the format:
-----BEGIN CERTIFICATE-----
-----END CERTIFICATE-----
and paste them in to the "Server SSL Certificate" tab under "Settings" in Kura. Then click the Apply button and restart Kura to update the keystore.
But when click the Apply button the result is a warning:
Warning
The provided information cannot be accepted. Please review.
Show Stack Trace
Unknown.Pg(http://192.168.1.19/kura)
Unknown.Xg(http://192.168.1.19/kura)
Unknown.Qrc(http://192.168.1.19/kura)
Unknown.Vrc(http://192.168.1.19/kura)
Unknown.ygb(http://192.168.1.19/kura)
Unknown.ugb(http://192.168.1.19/kura)
Unknown.Seb(http://192.168.1.19/kura)
Unknown.zfb(http://192.168.1.19/kura)
Unknown.Tr(http://192.168.1.19/kura)
Unknown.es(http://192.168.1.19/kura)
Unknown.onreadystatechange<(http://192.168.1.19/kura)
Unknown.Yh(http://192.168.1.19/kura)
Unknown._h(http://192.168.1.19/kura)
Unknown.$h/<(http://192.168.1.19/kura)
Unknown.anonymous(Unknown)
PLEASE HELP ME
Giuseppe
FUDForum. Page generated in 0.02922 seconds
