Default value for channels [message #1777198] |
Sun, 26 November 2017 18:27  |
I'm writing the implementation of my te923 weather station.
To update one channel, I do:
updateState(new ChannelUID(getThing().getUID(), c.getMappingName()),
new DecimalType(d[c.getPositionInResponse()]));
One of my issue is that data may not come directly to the weather station.
If the data is not available yet, I don't call updateState for this channel. As an example one of my temperature sensor may not send some data (due to intermittent connectivity issues).
My issue is on the control tab.
By default, the value is set to 0.
Example
Temperature Internal Channel: 21.4 °C
Humidity Internal Channel: 51 %
Temperature Channel 1: 0.0 °C
Humidity Channel 1: 0 %
I'm expecting something like
Temperature Channel 1: - (Not available yet)
Humidity Channel 1: - (Not available yet)
If I try to set
new DecimalType(Double.NaN));
I get the following error : Character N is neither a decimal digit number, decimal point, nor "e" notation exponential mark. (probably the first letter of NaN)
Do I do something wrong? Could I notify openHab or smarthome that my data is not (yet) available for a specific channel?
[Updated on: Mon, 27 November 2017 02:40] by Moderator
Re: Default value for channels [message #1777865 is a reply to message #1777234] |
Tue, 05 December 2017 08:12  |
Hi Gabriel,
By default, if a binding hasn't send any state update, the UI should simply show a "-" as a value and the item state is NULL.
Could you analyse why this is the case? I assume that you unknowingly set this through your binding as the framework doesn't do it for sure.
Kai
FUDForum. Page generated in 0.15842 seconds
