Xtext web support into Angular app [message #1777083] |
Fri, 24 November 2017 10:45 |
Hi all!
I'm trying to integrate the Xtext Ace editor automatically generated by Xtext into an Angular 5 application, but I'm having problems problems witht the integration.
Have you anyone try this? Is there any example that I could see?
Thanks in advance.
Best.
Re: Xtext web support into Angular app [message #1777090 is a reply to message #1777085] |
Fri, 24 November 2017 11:06 |
Hi!
Thanks for you reply and sorry for multiple post, I pressed several times the button and it posts it three times :(
Yes. I'm able to get the web editor running, out of Angular, and I'm also able to get Ace itself running inside of Angular.
My problem is with the integration step. I have to load extra js such as ace/ext/language_tools, xtext-ace that seems need jQuery. In that point is were I'm having the problems loading the scripts, and I'm not sure what exactly I need to load.
Thanks in advance.
FUDForum. Page generated in 0.02953 seconds
