Re: GMF tooling -- Problems with generating the gmfgen model [message #1785216 is a reply to message #1785156] |
Wed, 11 April 2018 06:12 |
To my knowledge, GMF Tooling is not maintained anymore. I'm not even sure anyone from the project is following this forum. The only suggestion I can give you is to keep an older version of Eclipse (pre-Oxygen) around for when you need to launch a GMF Tooling generation, even if you use a more recent Eclipse for the main development. The version of Eclipse (and the required dependencies) used to run the code generation phase does not need to be the version you use to develop the rest of the code, or the target version where the result application will be executed.
Pierre-Charles David - Obeo
FUDForum. Page generated in 0.04155 seconds
