How to install Eclipse Oxygen Scout behind a proxy [message #1776962] |
Thu, 23 November 2017 09:31 |
Hi All,
I have on my laptop the following version of Java
java version "1.8.0_151"
Java(TM) SE Runtime Environment (build 1.8.0_151-b12)
Java HotSpot(TM) 64-Bit Server VM (build 25.151-b12, mixed mode)
and the following version of maven
Apache Maven 3.5.2 (138edd61fd100ec658bfa2d307c43b76940a5d7d; 2017-10-1
3+02:00)
Maven home: C:\Program Files\apache-maven-3.5.2\bin\..
Java version: 1.8.0_121, vendor: Oracle Corporation
Java home: C:\Program Files\Java\jdk1.8.0_121\jre
Default locale: it_IT, platform encoding: Cp1252
OS name: "windows 7", version: "6.1", arch: "amd64", family: "windows"
with the browser I can reach this wed-site https://www.eclipse.org/downloads/packages/release/Oxygen/1A, but when run the installer return this error:
[2017-11-22 09:37:25] Executing bootstrap tasks
[2017-11-22 09:37:25] Java(TM) SE Runtime Environment 1.8.0_151-b12
[2017-11-22 09:37:25] Product org.eclipse.products.epp.package.scout.oxygen
[2017-11-22 09:37:25] Bundle org.eclipse.oomph.setup 1.8.0.v20170408-0745, build=3059, branch=2161405b80cf99ed791602ba56cdf44084f5ca43
[2017-11-22 09:37:25] Bundle org.eclipse.oomph.setup.core 1.8.0.v20170531-0903, build=3059, branch=2161405b80cf99ed791602ba56cdf44084f5ca43
[2017-11-22 09:37:25] Bundle org.eclipse.oomph.setup.p2 1.8.0.v20170318-0419, build=3059, branch=2161405b80cf99ed791602ba56cdf44084f5ca43
[2017-11-22 09:37:25] Performing P2 Director (Eclipse for Scout Developers (Oxygen))
[2017-11-22 09:37:25] Offline = false
[2017-11-22 09:37:25] Mirrors = true
[2017-11-22 09:37:25] Resolving 21 requirements from 3 repositories to C:\eclipse-oxygen\eclipse
[2017-11-22 09:37:25] Requirement epp.package.scout [4.7.0,4.8.0)
[2017-11-22 09:37:25] Requirement org.eclipse.platform.feature.group [4.7.0,4.8.0)
[2017-11-22 09:37:25] Requirement org.eclipse.rcp.feature.group [4.7.0,4.8.0)
[2017-11-22 09:37:25] Requirement org.eclipse.egit.feature.group
[2017-11-22 09:37:25] Requirement org.eclipse.egit.mylyn.feature.group
[2017-11-22 09:37:25] Requirement org.eclipse.help.source.feature.group
[2017-11-22 09:37:25] Requirement org.eclipse.jdt.feature.group
[2017-11-22 09:37:25] Requirement org.eclipse.jdt.source.feature.group
[2017-11-22 09:37:25] Requirement org.eclipse.jgit.feature.group
[2017-11-22 09:37:25] Requirement org.eclipse.jst.web_ui.feature.feature.group
[2017-11-22 09:37:25] Requirement org.eclipse.m2e.feature.feature.group
[2017-11-22 09:37:25] Requirement org.eclipse.mylyn.bugzilla_feature.feature.group
[2017-11-22 09:37:25] Requirement org.eclipse.mylyn.context_feature.feature.group
[2017-11-22 09:37:25] Requirement org.eclipse.mylyn.git.feature.group
[2017-11-22 09:37:25] Requirement org.eclipse.mylyn.ide_feature.feature.group
[2017-11-22 09:37:25] Requirement org.eclipse.mylyn.java_feature.feature.group
[2017-11-22 09:37:25] Requirement org.eclipse.mylyn.wikitext_feature.feature.group
[2017-11-22 09:37:25] Requirement org.eclipse.mylyn_feature.feature.group
[2017-11-22 09:37:25] Requirement org.eclipse.scout.sdk-feature.feature.group
[2017-11-22 09:37:25] Requirement org.eclipse.wst.xml_ui.feature.feature.group
[2017-11-22 09:37:25] Requirement org.eclipse.oomph.setup.feature.group
[2017-11-22 09:37:25] Repository http://download.eclipse.org/technology/epp/packages/oxygen
[2017-11-22 09:37:25] Repository http://download.eclipse.org/releases/oxygen
[2017-11-22 09:37:25] Repository http://download.eclipse.org/oomph/updates/milestone/latest
[2017-11-22 09:37:26] ERROR: org.eclipse.equinox.p2.transport.ecf code=1002 HTTP Proxy Authentication Required: http://download.eclipse.org/oomph/updates/milestone/latest/compositeContent.xml
ERROR: org.eclipse.ecf.identity code=0 Proxy Authentication Required
at org.eclipse.ecf.provider.filetransfer.httpclient4.HttpClientFileSystemBrowser.runRequest(HttpClientFileSystemBrowser.java:291)
at org.eclipse.ecf.provider.filetransfer.browse.AbstractFileSystemBrowser$DirectoryJob.run(AbstractFileSystemBrowser.java:69)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:56)
When the installer start ask me the user and password, and I insert my network credentials that are authorized to surf the web.
I want install Eclipse Oxygen with Scout behind proxy; what is the correct procedure to follow?
I already tried with installer but give me a problem when I want create a new project or I try to check the update and so on
Thanks in advance for your help and explanation
Marco
FUDForum. Page generated in 0.04066 seconds
