How to install Eclipse Oxygen Scout behind a proxy [message #1776692] |
Mon, 20 November 2017 14:19 |
Hi all,
I have on my laptop the following version of Java
java version "1.8.0_151"
Java(TM) SE Runtime Environment (build 1.8.0_151-b12)
Java HotSpot(TM) 64-Bit Server VM (build 25.151-b12, mixed mode)
and the following version of maven
Apache Maven 3.5.2 (138edd61fd100ec658bfa2d307c43b76940a5d7d; 2017-10-1
3+02:00)
Maven home: C:\Program Files\apache-maven-3.5.2\bin\..
Java version: 1.8.0_121, vendor: Oracle Corporation
Java home: C:\Program Files\Java\jdk1.8.0_121\jre
Default locale: it_IT, platform encoding: Cp1252
OS name: "windows 7", version: "6.1", arch: "amd64", family: "windows"
I want install Eclipse Oxygen with Scout behind proxy; what is the correct procedure to follow?
I already tried with installer but give me a problem when I want create a new project or I try to check the update and so on
Thanks in advance for your help and explanation
Marco
Re: How to install Eclipse Oxygen Scout behind a proxy [message #1776843 is a reply to message #1776841] |
Wed, 22 November 2017 08:44 |
Hi Matthias,
with the browser I can reach this wed-site, but when run the installer return this error:
[2017-11-22 09:37:25] Executing bootstrap tasks
[2017-11-22 09:37:25] Java(TM) SE Runtime Environment 1.8.0_151-b12
[2017-11-22 09:37:25] Product org.eclipse.products.epp.package.scout.oxygen
[2017-11-22 09:37:25] Bundle org.eclipse.oomph.setup 1.8.0.v20170408-0745, build=3059, branch=2161405b80cf99ed791602ba56cdf44084f5ca43
[2017-11-22 09:37:25] Bundle org.eclipse.oomph.setup.core 1.8.0.v20170531-0903, build=3059, branch=2161405b80cf99ed791602ba56cdf44084f5ca43
[2017-11-22 09:37:25] Bundle org.eclipse.oomph.setup.p2 1.8.0.v20170318-0419, build=3059, branch=2161405b80cf99ed791602ba56cdf44084f5ca43
[2017-11-22 09:37:25] Performing P2 Director (Eclipse for Scout Developers (Oxygen))
[2017-11-22 09:37:25] Offline = false
[2017-11-22 09:37:25] Mirrors = true
[2017-11-22 09:37:25] Resolving 21 requirements from 3 repositories to C:\eclipse-oxygen\eclipse
[2017-11-22 09:37:25] Requirement epp.package.scout [4.7.0,4.8.0)
[2017-11-22 09:37:25] Requirement org.eclipse.platform.feature.group [4.7.0,4.8.0)
[2017-11-22 09:37:25] Requirement org.eclipse.rcp.feature.group [4.7.0,4.8.0)
[2017-11-22 09:37:25] Requirement org.eclipse.egit.feature.group
[2017-11-22 09:37:25] Requirement org.eclipse.egit.mylyn.feature.group
[2017-11-22 09:37:25] Requirement org.eclipse.help.source.feature.group
[2017-11-22 09:37:25] Requirement org.eclipse.jdt.feature.group
[2017-11-22 09:37:25] Requirement org.eclipse.jdt.source.feature.group
[2017-11-22 09:37:25] Requirement org.eclipse.jgit.feature.group
[2017-11-22 09:37:25] Requirement org.eclipse.jst.web_ui.feature.feature.group
[2017-11-22 09:37:25] Requirement org.eclipse.m2e.feature.feature.group
[2017-11-22 09:37:25] Requirement org.eclipse.mylyn.bugzilla_feature.feature.group
[2017-11-22 09:37:25] Requirement org.eclipse.mylyn.context_feature.feature.group
[2017-11-22 09:37:25] Requirement org.eclipse.mylyn.git.feature.group
[2017-11-22 09:37:25] Requirement org.eclipse.mylyn.ide_feature.feature.group
[2017-11-22 09:37:25] Requirement org.eclipse.mylyn.java_feature.feature.group
[2017-11-22 09:37:25] Requirement org.eclipse.mylyn.wikitext_feature.feature.group
[2017-11-22 09:37:25] Requirement org.eclipse.mylyn_feature.feature.group
[2017-11-22 09:37:25] Requirement org.eclipse.scout.sdk-feature.feature.group
[2017-11-22 09:37:25] Requirement org.eclipse.wst.xml_ui.feature.feature.group
[2017-11-22 09:37:25] Requirement org.eclipse.oomph.setup.feature.group
[2017-11-22 09:37:25] Repository http://download.eclipse.org/technology/epp/packages/oxygen
[2017-11-22 09:37:25] Repository http://download.eclipse.org/releases/oxygen
[2017-11-22 09:37:25] Repository http://download.eclipse.org/oomph/updates/milestone/latest
[2017-11-22 09:37:26] ERROR: org.eclipse.equinox.p2.transport.ecf code=1002 HTTP Proxy Authentication Required: http://download.eclipse.org/oomph/updates/milestone/latest/compositeContent.xml
ERROR: org.eclipse.ecf.identity code=0 Proxy Authentication Required
at org.eclipse.ecf.provider.filetransfer.httpclient4.HttpClientFileSystemBrowser.runRequest(HttpClientFileSystemBrowser.java:291)
at org.eclipse.ecf.provider.filetransfer.browse.AbstractFileSystemBrowser$DirectoryJob.run(AbstractFileSystemBrowser.java:69)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:56)
When the installer start ask me the user and password, and I insert my network credentials that are authorized to surf the web.
Marco
Re: How to install Eclipse Oxygen Scout behind a proxy [message #1776960 is a reply to message #1776958] |
Thu, 23 November 2017 09:19 |
Hi Matthias,
thanks for the suggestions and I post the request .
I already try to download the package and install directly, but when I start to create a new project the same problem appears again.
This means that in the configuration there is something wrong or missing to work correctly with the proxy connection.
Marco
FUDForum. Page generated in 0.01806 seconds
