Home » Eclipse Projects » Papyrus for Real Time » How to make template member function
How to make template member function [message #1776620] Sat, 18 November 2017 16:57 Go to next message
Sekwon Jang is currently offline Sekwon JangFriend
I need to make template member function given below :
template <typename T>
void testf(T data) {
I found template parameter option in Advanced Tab in properties of operation and parameter and set template option to function and parameter.
But these options didn't sustain and didn't make template member function.
Re: How to make template member function [message #1776704 is a reply to message #1776620] Mon, 20 November 2017 15:20 Go to previous message
Ernesto Posse is currently offline Ernesto PosseFriend
Hi. Papyrus-RT doesn't have direct support for templates (either class or function templates). However there is a workaround, for function templates at least. You can use the "publicDeclarations", "protectedDeclarations" or "privateDeclarations" properties of the "CapsuleProperties" or the "PassiveClassProperties" stereotypes. Essentially you can put any (legal) declaration in these fields. See the attached model and generated code for an example.
Previous Topic:scope of trigger/message parameters
Next Topic:What is the best way to add comments to model elements?
Current Time: Mon Jan 27 06:06:29 GMT 2020
Powered by FUDForum. Page generated in 0.02113 seconds
