Home » Modeling » TMF (Xtext) » (Xbase)Method refers to missing type .. : List Values cannot get passed as parameter or return value
(Xbase)Method refers to missing type .. : List Values cannot get passed as parameter or return value [message #1776469] Thu, 16 November 2017 16:27 Go to next message
René Bärnreuther is currently offline René BärnreutherFriend
Member
I'm currently struggeling to implement list types correctly because they cannot be passed as Parameter to my operations (the error "the method e(Java.util.List<Integer>) from the type Test5 (my generated class) refers to the missing type java.util.list<Integer>). I achieve the same behaviour when I try do return a List from a operation and set it to a variable of the expected list type.
The important parts of my DSL are the following:
Grammar:
Variable returns XVariableDeclaration:
	{Variable} writeable?='variable' simpleName=ID  ':' (typing=DataType);
Method:
	=> ({Method} 'operation' name=ValidID
	'(') (parameter+=Parameter (',' parameter+=Parameter)*)? ')' ('returns' returnTyping=DataType)?
	body=XBlockExpression;
Parameter:
	{Parameter} 'parameter' name=ID ':' parameterTyping=DataType;
// more stuff [..]
DataType:
	(SimpleDataType | ComplexDataType | ListType);
ListType:
	=> ('list' '<' type=DataType) '>';
SimpleDataType:
	{SimpleDataType} typeName=('integer' | 'string' | 'rational' | 'boolean');
To use ComplexDataTypes and SimpleDataTypes as variables works as expected. Return-values work, too.
My typecomputer looks like this:
if(XVariableDeclaration instanceof Variable){
/* other types, simple datatype and complex data type */
 /* ... */ else if (vr.typing instanceof ListType) {
			state.assignType(vr, getTypeForName(listTypeUtil.getListTypeString(vr.typing as ListType), state))
			for (additional : vr.additionalVariables) {
				state.assignType(additional,
The getListTypeString method returns for the variable "list<integer>" the type "java.util.List<Integer>" and works like this similiar for other cases.
My compiler looks like this:
	override _toJavaStatement(XVariableDeclaration variable, ITreeAppendable a, boolean isReferenced) {
		variable.name = variable.simpleName
		if (variable instanceof Variable) {
			a.newLine()
			if (variable.typing instanceof SimpleDataType) {
				a.append(createAppendString(variable.typing as SimpleDataType, variable))
			} else if (variable.typing instanceof ComplexDataType) { /* ComplexDataType */
				a.append(createAppendString(variable.typing as ComplexDataType, variable))
			} else if (variable.typing instanceof ListType) {
				a.append(createAppendString(variable.typing as ListType, variable))
		} else {
			super._toJavaStatement(variable, a, isReferenced)
	/* Creates variable declaration of list type  */
	def createAppendString(ListType lt, Variable vr) {
		var appendString = ""
		appendString += "java.util.List<"
		appendString += calculateInnerTypeString(lt)
		appendString += "> "
		appendString += vr.simpleName
		appendString += " = new java.util.ArrayList<"
		appendString += ">();"
InnerTypeString calculates the innertypes of the List. For list<string> it will return "String".
An example translation looks like the following:
variable liste: list<integer>
-> java.util.List<Integer> liste = new java.util.ArrayList<Integer>();
This works as expected (at least as far as I know, maybe there are better ways..).
My operations in the inferrer will be converted like this:
	 * Generates all operations in the program
	def inferMethods(List<Method> methods, List<JvmMember> members) {
		for (method : methods) {
			var type = method.returnTyping
			var returntype = getTypeRefFor(type)
			if (returntype === null) {
				returntype = typeRef(Void.TYPE)
			members += method.toMethod(method.name, returntype) [
				for (param : method.parameter) {
					parameters += param.toParameter(param.name, getTypeRefFor(param.parameterTyping))
				static = true
				body = method.body
	 * Returns the typeRef for the given datatype
	 * null, if no type is found
	def /* @nullable */ getTypeRefFor(DataType parameterType) {
		println(parameterType)
		if (parameterType instanceof SimpleDataType) {
			return getSimpleDataType(parameterType.typeName)
		} else if (parameterType instanceof ComplexDataType) {
			var cdt = parameterType as ComplexDataType
			if (cdt.typeName instanceof Composition) {
				return typeRef((cdt.typeName as Composition).name)
			} else if (cdt.typeName instanceof Enumeration) {
				return typeRef((cdt.typeName as Enumeration).name)
		} else if (parameterType instanceof ListType) {
			return typeRef("java.util.List<" + calculateInnerTypeString(parameterType as ListType) + ">")
		} else {
			return null
So it will return "java.util.List<String>" for a returnvalue of "list<string>".
The problem arises for calls like this:
operation e(parameter l : list<integer>){
main {
	variable listInt : list<integer>;
	listInt <-- [1,2,3]; // puts in 1,2,3 in the list
	e(listInt);
On e the error mentioned above arrises and I'm not sure why.
My guess would be that I need to type the Method and the Parameter for it explictly, is this correct or do I need to change something else to make this work?
If there are any more relevant details I forgot, feel free to ask for them.
Thanks in Advance!
Re: (Xbase)Method refers to missing type .. : List Values cannot get passed as parameter or return v [message #1776474 is a reply to message #1776469] Thu, 16 November 2017 18:29 Go to previous message
Christian Dietrich is currently offline Christian DietrichFriend
the typeRef method looks like org.eclipse.xtext.xbase.jvmmodel.JvmTypeReferenceBuilder.typeRef(String, JvmTypeReference...)
so i would have expected to use
typeRef("java.util.List", typeRef("java.lang.String"))
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Previous Topic:Two DSL in same project
Next Topic:Auto-completion not working
Current Time: Mon Aug 15 19:16:18 GMT 2022
Powered by FUDForum. Page generated in 0.01945 seconds
