Home » Modeling » TMF (Xtext) » Model serialization problem
Model serialization problem [message #1776416] Thu, 16 November 2017 10:02 Go to next message
mind calm is currently offline mind calmFriend
Member
I use xtext + sirius to edit my model.
part of Xtext defined in meta-model as flow:
Requirement returns Requirement:
	'Requirement'
	identifier=EString
		('count' count=EInt)?
		('mandatory' mandatory=EBoolean)?
		'type' type=[ApplicationType|EString]
		('applications' '(' applications+=[ApplicationInstance|EString] ( "," applications+=[ApplicationInstance|EString])* ')' )?
If i didn't set 'type' of a 'Requirement' in sirius diagram editor, then i can't save the model.
Values: identifier(1), count(0-1), mandatory(0-1)
Semantic Object: CyberPhysicalSystem.requests[0]->Request.requirements[0]->Requirement
URI: platform:/resource/cpsTest/f1.cyberphysicalsystem
Context: Requirement returns Requirement
	at org.eclipse.xtext.serializer.diagnostic.ISerializationDiagnostic$ExceptionThrowingAcceptor.accept(ISerializationDiagnostic.java:131)
	at org.eclipse.xtext.serializer.sequencer.BacktrackingSemanticSequencer.createSequence(BacktrackingSemanticSequencer.java:480)
	at org.eclipse.viatra.examples.cps.model.dsl.serializer.CPSSemanticSequencer.sequence_Requirement(CPSSemanticSequencer.java:200)
	at org.eclipse.viatra.examples.cps.model.dsl.serializer.CPSSemanticSequencer.sequence(CPSSemanticSequencer.java:62)
I think in some scenarios, we should serialize the model successfully, even if there is some unset properties.
Is there any options or switch to ignore the null property in model?
Best regards!
by Keep Mind Calm
[Updated on: Thu, 16 November 2017 10:03]
Report message to a moderator
Re: Model serialization problem [message #1776418 is a reply to message #1776416] Thu, 16 November 2017 10:17 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
But the type is required in the grammar ?!?
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: Model serialization problem [message #1776648 is a reply to message #1776418] Mon, 20 November 2017 01:33 Go to previous messageGo to next message
Member
Yes, the 'type' is required in the grammar.
Whether we can serialize the model without 'type' or with the 'type' empty?
Best regards!
by Keep Mind Calm
Re: Model serialization problem [message #1776655 is a reply to message #1776648] Mon, 20 November 2017 04:41 Go to previous messageGo to next message
But that model would be broken?
Re: Model serialization problem [message #1776656 is a reply to message #1776655] Mon, 20 November 2017 05:38 Go to previous messageGo to next message
Member
I don't think model would be broken.
Such as the Requirement grammar mentioned above,
	'Requirement'
	identifier=EString
in Sirius editor, if user did not set value of 'type' for a 'Requirement' instance, we can serialize it as blow:
    Requirement "requirement1" {
        count 0
        applications ("***", "***")
there is no 'type' and 'mandatory' information.
Of course, if some property use as identifier, it must have a value.
Best regards!
by Keep Mind Calm
Re: Model serialization problem [message #1776660 is a reply to message #1776656] Mon, 20 November 2017 06:14 Go to previous messageGo to next message
no this model would be invalid.
the grammar says ther has to be a type?
so why dont you simply make it optional in the grammar?
[Updated on: Mon, 20 November 2017 06:15]
Re: Model serialization problem [message #1776666 is a reply to message #1776660] Mon, 20 November 2017 07:35 Go to previous message
Member
Ok, got it, now the only way is to change the grammar. thanks for your reply.
Best regards!
by Keep Mind Calm
Previous Topic:Internal error occurred during: "Launching Launch Runtime Eclipse"
Next Topic:Xtext web editor is disabled
Current Time: Sun Oct 24 10:46:16 GMT 2021
Powered by FUDForum. Page generated in 0.02427 seconds
