Re: console view won't open [message #1776389 is a reply to message #1776383] |
Thu, 16 November 2017 06:50 |
You need to make a autoexec.cfg file in cs directory, with your fps_max command in there. CSGO will run the cfg when you open it, limiting it to 60fps (if 60 is indicated after fps_max)
Re: console view won't open [message #1776399 is a reply to message #1776389] |
Thu, 16 November 2017 08:06 |
Ed Merks Messages: 33141 Registered: July 2009 |
Priya, you appear to try to help with a daily post on the JDT forum, but I most often am left scratching my head whether what you say is actually related to the question being asked. You're post today seems particularly off kilter.
Bruce, is the Error Log view coming to the top, hiding the Console view. If you type "Console" in the "Quick Access" box (typically in the upper right just to the left of the perspective selection toolbar items), and choose Console (General), does that show the Console view? If you type "Error Log" in the "Quick Access" does the Error Log view show, and is there an error logged, related to your previously described problem. You can clear all the logged problems and try to run your program again to be sure the logged entry is produced from your action attempting to run your program (I assume it's Java). With the stack trace associated with this logged error, it's more likely someone can help you.
Ed Merks
FUDForum. Page generated in 0.03439 seconds
