Installing Eclipse [message #1776278] |
Tue, 14 November 2017 14:48  |
I installed an additional hard drive on my computer. After I did I made the mistake of moving some programming files and it lost my settings. I uninstalled Eclipse and java. I reinstalled Java and tried to install Eclipse.
I can download the install file eclipse-inst-win64.exe, no matter what I do the installer won't start. I tried to download and extract the files for java and c separately but they won't run.
Is there a hidden file somewhere I need to remove from my computer to be able to run the eclipse installer?
When I click on it, right click and open, or run as administrator nothing happens.
Re: Installing Eclipse [message #1776343 is a reply to message #1776311] |
Wed, 15 November 2017 08:54   |
i have a long issue, i instated it previously and it worked, but had a few issues with it so i uninstalled it and reinstalled it and now this shows up
[2017-11-15 07:28:00] Executing bootstrap tasks
[2017-11-15 07:28:00] Java(TM) SE Runtime Environment 1.8.0_151-b12
[2017-11-15 07:28:00] Product org.eclipse.products.epp.package.java.oxygen
[2017-11-15 07:28:00] Bundle org.eclipse.oomph.setup 1.8.0.v20170408-0745, build=3059, branch=2161405b80cf99ed791602ba56cdf44084f5ca43
[2017-11-15 07:28:00] Bundle org.eclipse.oomph.setup.core 1.8.0.v20170531-0903, build=3059, branch=2161405b80cf99ed791602ba56cdf44084f5ca43
[2017-11-15 07:28:00] Bundle org.eclipse.oomph.setup.p2 1.8.0.v20170318-0419, build=3059, branch=2161405b80cf99ed791602ba56cdf44084f5ca43
[2017-11-15 07:28:00] Performing P2 Director (Eclipse IDE for Java Developers (Oxygen))
[2017-11-15 07:28:00] Offline = false
[2017-11-15 07:28:00] Mirrors = true
[2017-11-15 07:28:00] Resolving 24 requirements from 3 repositories to C:\Users\Peg\eclipse\java-oxygen2\eclipse
[2017-11-15 07:28:00] Requirement epp.package.java [4.7.0,4.8.0)
[2017-11-15 07:28:00] Requirement org.eclipse.platform.feature.group [4.7.0,4.8.0)
[2017-11-15 07:28:00] Requirement org.eclipse.rcp.feature.group [4.7.0,4.8.0)
[2017-11-15 07:28:00] Requirement org.eclipse.buildship.feature.group
[2017-11-15 07:28:00] Requirement org.eclipse.eclemma.feature.feature.group
[2017-11-15 07:28:00] Requirement org.eclipse.egit.feature.group
[2017-11-15 07:28:00] Requirement org.eclipse.egit.mylyn.feature.group
[2017-11-15 07:28:00] Requirement org.eclipse.jdt.feature.group
[2017-11-15 07:28:00] Requirement org.eclipse.jgit.feature.group
[2017-11-15 07:28:00] Requirement org.eclipse.m2e.feature.feature.group
[2017-11-15 07:28:00] Requirement org.eclipse.m2e.logback.feature.feature.group
[2017-11-15 07:28:00] Requirement org.eclipse.mylyn.bugzilla_feature.feature.group
[2017-11-15 07:28:00] Requirement org.eclipse.mylyn.context_feature.feature.group
[2017-11-15 07:28:00] Requirement org.eclipse.mylyn.git.feature.group
[2017-11-15 07:28:00] Requirement org.eclipse.mylyn.hudson.feature.group
[2017-11-15 07:28:00] Requirement org.eclipse.mylyn.ide_feature.feature.group
[2017-11-15 07:28:00] Requirement org.eclipse.mylyn.java_feature.feature.group
[2017-11-15 07:28:00] Requirement org.eclipse.mylyn.wikitext_feature.feature.group
[2017-11-15 07:28:00] Requirement org.eclipse.mylyn_feature.feature.group
[2017-11-15 07:28:00] Requirement org.eclipse.recommenders.mylyn.rcp.feature.feature.group
[2017-11-15 07:28:00] Requirement org.eclipse.recommenders.rcp.feature.feature.group
[2017-11-15 07:28:00] Requirement org.eclipse.recommenders.snipmatch.rcp.feature.feature.group
[2017-11-15 07:28:00] Requirement org.eclipse.wst.xml_ui.feature.feature.group
[2017-11-15 07:28:00] Requirement org.eclipse.oomph.setup.feature.group
[2017-11-15 07:28:00] Repository http://download.eclipse.org/technology/epp/packages/oxygen
[2017-11-15 07:28:00] Repository http://download.eclipse.org/releases/oxygen
[2017-11-15 07:28:00] Repository http://download.eclipse.org/oomph/updates/milestone/latest
[2017-11-15 07:28:01] ERROR: org.eclipse.equinox.p2.metadata.repository code=1002 Unable to read repository at http://download.eclipse.org/releases/oxygen.
ERROR: org.eclipse.equinox.p2.repository code=0 An error occurred while downloading http://download.eclipse.org/technology/epp/packages/oxygen/content.xml.xz. The cache file C:\Users\Peg\.p2\org.eclipse.equinox.p2.repository\cache\downloading\-1747184149 could not be renamed to C:\Users\Peg\.p2\org.eclipse.equinox.p2.repository\cache\-1747184149.
at org.eclipse.equinox.internal.p2.repository.CacheManager.updateCache(CacheManager.java:428)
at org.eclipse.equinox.internal.p2.repository.CacheManager.createCacheFromFile(CacheManager.java:132)
at org.eclipse.equinox.internal.p2.metadata.repository.XZedSimpleMetadataRepositoryFactory.getLocalFile(XZedSimpleMetadataRepositoryFactory.java:56)
at org.eclipse.equinox.internal.p2.metadata.repository.XZedSimpleMetadataRepositoryFactory.load(XZedSimpleMetadataRepositoryFactory.java:78)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.factoryLoad(MetadataRepositoryManager.java:57)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:768)
at org.eclipse.oomph.util.ReflectUtil.invokeMethod(ReflectUtil.java:117)
at org.eclipse.oomph.p2.internal.core.CachingRepositoryManager.loadRepository(CachingRepositoryManager.java:409)
at org.eclipse.oomph.p2.internal.core.CachingRepositoryManager.loadRepository(CachingRepositoryManager.java:201)
at org.eclipse.oomph.p2.internal.core.CachingRepositoryManager$Metadata.loadRepository(CachingRepositoryManager.java:476)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:96)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:92)
at org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepository.addChild(CompositeMetadataRepository.java:166)
at org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepository.<init>(CompositeMetadataRepository.java:106)
at org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepositoryFactory.load(CompositeMetadataRepositoryFactory.java:122)
at org.eclipse.oomph.p2.internal.core.ProfileTransactionImpl$RepositoryLoader$Worker.perform(ProfileTransactionImpl.java:1613)
at org.eclipse.oomph.util.WorkerPool$Worker.run(WorkerPool.java:428)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:56)
i would be so grateful if anyone could help
Re: Installing Eclipse [message #1776371 is a reply to message #1776352] |
Wed, 15 November 2017 13:23   |
okay, I made the folder to be ignored by windows defender... i like to live life dangerously and dont really have much for anti virus...
new error message though
[2017-11-15 12:17:53] Executing bootstrap tasks
[2017-11-15 12:17:53] Java(TM) SE Runtime Environment 1.8.0_151-b12
[2017-11-15 12:17:53] Product org.eclipse.products.epp.package.java.oxygen
[2017-11-15 12:17:53] Bundle org.eclipse.oomph.setup 1.8.0.v20170408-0745, build=3059, branch=2161405b80cf99ed791602ba56cdf44084f5ca43
[2017-11-15 12:17:53] Bundle org.eclipse.oomph.setup.core 1.8.0.v20170531-0903, build=3059, branch=2161405b80cf99ed791602ba56cdf44084f5ca43
[2017-11-15 12:17:53] Bundle org.eclipse.oomph.setup.p2 1.8.0.v20170318-0419, build=3059, branch=2161405b80cf99ed791602ba56cdf44084f5ca43
[2017-11-15 12:17:53] Performing P2 Director (Eclipse IDE for Java Developers (Oxygen))
[2017-11-15 12:17:53] Offline = false
[2017-11-15 12:17:53] Mirrors = true
[2017-11-15 12:17:53] Resolving 24 requirements from 3 repositories to C:\Users\Peg\eclipse\java-oxygen\eclipse
[2017-11-15 12:17:53] Requirement epp.package.java [4.7.0,4.8.0)
[2017-11-15 12:17:53] Requirement org.eclipse.platform.feature.group [4.7.0,4.8.0)
[2017-11-15 12:17:53] Requirement org.eclipse.rcp.feature.group [4.7.0,4.8.0)
[2017-11-15 12:17:53] Requirement org.eclipse.buildship.feature.group
[2017-11-15 12:17:53] Requirement org.eclipse.eclemma.feature.feature.group
[2017-11-15 12:17:53] Requirement org.eclipse.egit.feature.group
[2017-11-15 12:17:53] Requirement org.eclipse.egit.mylyn.feature.group
[2017-11-15 12:17:53] Requirement org.eclipse.jdt.feature.group
[2017-11-15 12:17:53] Requirement org.eclipse.jgit.feature.group
[2017-11-15 12:17:53] Requirement org.eclipse.m2e.feature.feature.group
[2017-11-15 12:17:53] Requirement org.eclipse.m2e.logback.feature.feature.group
[2017-11-15 12:17:53] Requirement org.eclipse.mylyn.bugzilla_feature.feature.group
[2017-11-15 12:17:53] Requirement org.eclipse.mylyn.context_feature.feature.group
[2017-11-15 12:17:53] Requirement org.eclipse.mylyn.git.feature.group
[2017-11-15 12:17:53] Requirement org.eclipse.mylyn.hudson.feature.group
[2017-11-15 12:17:53] Requirement org.eclipse.mylyn.ide_feature.feature.group
[2017-11-15 12:17:53] Requirement org.eclipse.mylyn.java_feature.feature.group
[2017-11-15 12:17:53] Requirement org.eclipse.mylyn.wikitext_feature.feature.group
[2017-11-15 12:17:53] Requirement org.eclipse.mylyn_feature.feature.group
[2017-11-15 12:17:53] Requirement org.eclipse.recommenders.mylyn.rcp.feature.feature.group
[2017-11-15 12:17:53] Requirement org.eclipse.recommenders.rcp.feature.feature.group
[2017-11-15 12:17:53] Requirement org.eclipse.recommenders.snipmatch.rcp.feature.feature.group
[2017-11-15 12:17:53] Requirement org.eclipse.wst.xml_ui.feature.feature.group
[2017-11-15 12:17:53] Requirement org.eclipse.oomph.setup.feature.group
[2017-11-15 12:17:53] Repository http://download.eclipse.org/technology/epp/packages/oxygen
[2017-11-15 12:17:53] Repository http://download.eclipse.org/releases/oxygen
[2017-11-15 12:17:53] Repository http://download.eclipse.org/oomph/updates/milestone/latest
[2017-11-15 12:17:59] Calculating requirements and dependencies.
[2017-11-15 12:17:59] Computing prerequisite plan
[2017-11-15 12:18:00] Fetching artifacts.xml.xz from http://download.eclipse.org/technology/epp/packages/oxygen/
[2017-11-15 12:18:01] Fetching artifacts.xml.xz from http://download.eclipse.org/releases/oxygen/201709271000/
[2017-11-15 12:18:01] Collecting 1 artifacts from http://download.eclipse.org/technology/epp/packages/oxygen
[2017-11-15 12:18:02] Downloading epp.package.java.executable.win32.win32.x86_64
[2017-11-15 12:18:02] Collected 1 artifacts for http://download.eclipse.org/technology/epp/packages/oxygen in 0.214s
[2017-11-15 12:18:02] Collecting 3 artifacts from http://download.eclipse.org/releases/oxygen
[2017-11-15 12:18:02] Downloading org.eclipse.platform.ide.executable.win32.win32.x86_64
[2017-11-15 12:18:02] Downloading org.eclipse.platform_root
[2017-11-15 12:18:02] Downloading org.eclipse.rcp_root
[2017-11-15 12:18:02] Collected 3 artifacts for http://download.eclipse.org/releases/oxygen in 0.271s
[2017-11-15 12:18:03] An error was detected while performing the engine operation and the changes are being rolled back. See the log for details.
[2017-11-15 12:18:03] ERROR: org.eclipse.equinox.p2.engine code=4 An error occurred during the org.eclipse.equinox.internal.p2.engine.phases.CheckTrust phase.
at org.eclipse.oomph.util.OomphPlugin.coreException(OomphPlugin.java:280)
at org.eclipse.oomph.p2.internal.core.ProfileTransactionImpl$3.commit(ProfileTransactionImpl.java:547)
at org.eclipse.oomph.p2.internal.core.ProfileTransactionImpl.commit(ProfileTransactionImpl.java:340)
at org.eclipse.oomph.setup.p2.impl.P2TaskImpl.perform(P2TaskImpl.java:729)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.doPerformNeededSetupTasks(SetupTaskPerformer.java:3324)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performNeededSetupTasks(SetupTaskPerformer.java:3252)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performTriggeredSetupTasks(SetupTaskPerformer.java:3233)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.perform(SetupTaskPerformer.java:3133)
at org.eclipse.oomph.setup.internal.installer.SimpleVariablePage.installPerform(SimpleVariablePage.java:1289)
at org.eclipse.oomph.setup.internal.installer.SimpleVariablePage.access$32(SimpleVariablePage.java:1166)
at org.eclipse.oomph.setup.internal.installer.SimpleVariablePage$20.run(SimpleVariablePage.java:1111)
ERROR: org.eclipse.equinox.p2.engine code=0 session context was:(profile=C__Users_Peg_eclipse_java-oxygen_eclipse, phase=org.eclipse.equinox.internal.p2.engine.phases.CheckTrust, operand=, action=).
ERROR: org.eclipse.equinox.p2.engine code=0 Error reading signed content.
java.io.IOException: Exception in opening zip file: C:\Users\Peg\.p2\pool\plugins\org.eclipse.aether.maven_3.1.0.v20140706-2237.jar
at org.eclipse.osgi.framework.util.SecureAction.getZipFile(SecureAction.java:321)
at org.eclipse.osgi.internal.signedcontent.SignedBundleHook.getSignedContent(SignedBundleHook.java:212)
at org.eclipse.equinox.internal.p2.engine.phases.CertificateChecker.checkCertificates(CertificateChecker.java:74)
at org.eclipse.equinox.internal.p2.engine.phases.CertificateChecker.start(CertificateChecker.java:55)
at org.eclipse.equinox.internal.p2.engine.phases.CheckTrust.completePhase(CheckTrust.java:52)
at org.eclipse.equinox.internal.p2.engine.Phase.postPerform(Phase.java:252)
at org.eclipse.equinox.internal.p2.engine.Phase.perform(Phase.java:102)
at org.eclipse.equinox.internal.p2.engine.PhaseSet.perform(PhaseSet.java:47)
at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:77)
at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:45)
at org.eclipse.equinox.internal.provisional.p2.director.PlanExecutionHelper.executePlan(PlanExecutionHelper.java:42)
at org.eclipse.oomph.p2.internal.core.ProfileTransactionImpl$3.commit(ProfileTransactionImpl.java:543)
Caused by: java.io.FileNotFoundException: C:\Users\Peg\.p2\pool\plugins\org.eclipse.aether.maven_3.1.0.v20140706-2237.jar (The system cannot find the file specified)
at java.util.zip.ZipFile.open(Native Method)
at java.util.zip.ZipFile.<init>(Unknown Source)
at org.eclipse.osgi.framework.util.SecureAction.getZipFile(SecureAction.java:304)
... 1 more
atleast it made it farther this time
side note, when i was uninstalling, i did a search for eclipse across all of my c drive and deleted everything it would let me (might have been a bad idea in retrospect) i dont think that would completely destroy my os but idk, im interested in java not doss/c++/ whatever an os is made in
EDIT: i solved it, made the anti virus ignore .p2 aswell
[Updated on: Wed, 15 November 2017 13:34] by Moderator
Re: Installing Eclipse [message #1776400 is a reply to message #1776380] |
Thu, 16 November 2017 03:09  |
Thanks for confirming it was indeed an anti-virus problem. It's really darned hard to write software that's robust when the OS (the anti-virus implementation of the OS) temporarily locks/blocks operations on files. :-(
FUDForum. Page generated in 0.06610 seconds
