Re: Add all ecore Files in Workspace as Semantic Resource [message #1776161 is a reply to message #1776156] |
Mon, 13 November 2017 10:19 |
On your modeling project (in the Model Explorer view), on the "Project Dependencies" you have a contextual menu "Add model". This will open a dialog window to choose a model from the workspace or from the file system.
Also note that Session.getSemanticResources() will return all semantic resources used wherever they are in the project or not.
Steve
Steve Monnier - Obeo Canada
Re: Add all ecore Files in Workspace as Semantic Resource [message #1776180 is a reply to message #1776168] |
Mon, 13 November 2017 13:46 |
Hello again,
Ah ok you want to do it programatically. You can create the URI using URI.createPlatformResourceURI(path, true) where path is "/project-name/path-to-my-model" and then you execute the org.eclipse.sirius.tools.api.command.semantic.AddSemanticResourceCommand like this:
Command addSemanticResourceCmd = new AddSemanticResourceCommand(session, semanticResourceURI, new NullProgressMonitor());
session.getTransactionalEditingDomain().getCommandStack().execute(addSemanticResourceCmd);
You can find many test using this command if you need to have a look.
Steve
FUDForum. Page generated in 0.03629 seconds
