Home » Eclipse Projects » OM2M » Error when building om2m(I clone OM2M, but have some bug when building.)
Error when building om2m [message #1775973] Wed, 08 November 2017 17:34 Go to next message
hieu tran is currently offline hieu tranFriend
I'm reading http://wiki.eclipse.org/OM2M/one/Clone. In step Build OM2M using Eclipse, having a bug (in my enclosed file). Can you help me fix it ?
  • Attachment: error.png
    (Size: 170.11KB, Downloaded 209 times)
Re: Error when building om2m [message #1776043 is a reply to message #1775973] Thu, 09 November 2017 17:07 Go to previous messageGo to next message
Mahdi Ben Alaya is currently offline Mahdi Ben AlayaFriend
Which java version are you using ?
Please try with java 8
Re: Error when building om2m [message #1776047 is a reply to message #1776043] Fri, 10 November 2017 03:31 Go to previous messageGo to next message
I'm using JAVA 1.8.0_151. The bug seems in java code.
Now, weather i should try other version java or not ?
[ERROR] \oneM2M\git\org.eclipse.om2m\org.eclipse.om2m.sdt\org.eclipse.om2m.sdt.home.netatmo\src\test\java\org\eclipse\om2m\sdt\home\netatmo\sdt\SDTWelcomeCameraDeviceTestCase.java:[41,38] error: cannot find symbol
Re: Error when building om2m [message #1776052 is a reply to message #1776047] Fri, 10 November 2017 07:29 Go to previous messageGo to next message
Th build works for you in command line ?
Re: Error when building om2m [message #1776069 is a reply to message #1776052] Fri, 10 November 2017 11:34 Go to previous messageGo to next message
I'm using Windown 7. Whether i have to install ubuntu or not ?
Have any guide to build works in command line in windown ?
Re: Error when building om2m [message #1776078 is a reply to message #1776069] Fri, 10 November 2017 13:45 Go to previous messageGo to next message
You have to install git and maven on Window. That's all.
Re: Error when building om2m [message #1776366 is a reply to message #1776078] Wed, 15 November 2017 17:51 Go to previous messageGo to next message
Thanks for your advice. I build successfully.
[Updated on: Thu, 16 November 2017 06:52]
Report message to a moderator
Re: Error when building om2m [message #1785881 is a reply to message #1776366] Sun, 22 April 2018 09:35 Go to previous messageGo to next message
Binh Phi is currently offline Binh PhiFriend
I have same problem when run om2m. Can you give me solution for this bug?
Re: Error when building om2m [message #1785884 is a reply to message #1776366] Sun, 22 April 2018 10:07 Go to previous messageGo to next message
i have same problem when build OM2M. Can you give me solution for this bug
Re: Error when building om2m [message #1785885 is a reply to message #1785884] Sun, 22 April 2018 10:28 Go to previous messageGo to next message
Which java version are using ?
Re: Error when building om2m [message #1785889 is a reply to message #1785885] Sun, 22 April 2018 14:09 Go to previous messageGo to next message
i use jdk1.8.0_151 and build on windows 10
Re: Error when building om2m [message #1785896 is a reply to message #1785889] Sun, 22 April 2018 17:01 Go to previous messageGo to next message
Could you please show the log ?
Re: Error when building om2m [message #1785905 is a reply to message #1785884] Mon, 23 April 2018 02:59 Go to previous messageGo to next message
You should download GIT for windown and build with command line.
Re: Error when building om2m [message #1785906 is a reply to message #1785905] Mon, 23 April 2018 03:35 Go to previous messageGo to next message
thank you. I have built successfully
Re: Error when building om2m [message #1790594 is a reply to message #1785905] Wed, 13 June 2018 10:50 Go to previous messageGo to next message
Francesco Rinaldi is currently offline Francesco RinaldiFriend
Hi, I've the same issue building with eclipse.
I've successfully build om2m with command line, but I want it also on eclipse(I'm following the official guide). why it doesn't build?
Thanks in advance
Re: Error when building om2m [message #1800474 is a reply to message #1790594] Sat, 29 December 2018 08:07 Go to previous message
Francesco Rinaldi wrote on Wed, 13 June 2018 10:50
Thanks in advance
Plugin maven intergrated for eclipse is the reason of error. You shoud install maven independently with eclipse. Then, adding to eclipse.
Previous Topic:ResourceType: 24 is not implemented
Next Topic:HTTPS notifications
Current Time: Fri Jan 22 17:22:22 GMT 2021
Powered by FUDForum. Page generated in 0.02436 seconds
