Home » Newcomers » Newcomers » Eclipse Error(Eclipse won't install correctly, I keep getting errors.)
Eclipse Error [message #1775940] Wed, 08 November 2017 13:36 Go to next message
Muneeb Khan is currently offline Muneeb KhanFriend
Hi, so I'm trying to get eclipse, and I have already installed Java 1.8 but now I keep getting an error message when I install eclipse oxygen for both Java and C/C++.
The bar reaches the end and then it just fails. The error log states:
ERROR: org.eclipse.equinox.p2.engine code=4
The whole file is attached in case you need it.
  • Attachment: Error Log.txt
    (Size: 10.81KB, Downloaded 119 times)
Best Regards
Muneeb Khan
~ murk3000
Re: Eclipse Error [message #1775957 is a reply to message #1775940] Wed, 08 November 2017 15:17 Go to previous messageGo to next message
Sometimes virus scanners on Windows will lock *.zip/*.jar files the moment they're downloaded into the file system, preventing them from being moved causing problems just like the one you should. I assume the file C:\Users\HP\.p2\pool\plugins\org.apache.lucene.analyzers-smartcn_6.1.0.v20161115-1612.jar is not present in the file system. Are there any files in the C:\Users\HP\.p2\org.eclipse.equinox.p2.repository\cache\downloading folder?
Ed Merks
Re: Eclipse Error [message #1775963 is a reply to message #1775957] Wed, 08 November 2017 15:49 Go to previous messageGo to next message
Thank you for getting back to me so fast!
You are correct, the file org.apache.lucene.analyzers-common_6.1.0.v20161115-1612 isn't in that file system. Although, a similar file, org.apache.lucene.analyzers-common_6.1.0.v20161115-1612.jar, is present.
And no, there are no files in the downloading folder. Should there be?
Best Regards
Muneeb Khan
~ murk3000
Re: Eclipse Error [message #1775971 is a reply to message #1775963] Wed, 08 November 2017 17:26 Go to previous messageGo to next message
Sometimes the files get "stuck" in the downloading folder, so that seems not to be the case. It fails exactly the same what each time you try?
Ed Merks
Re: Eclipse Error [message #1775976 is a reply to message #1775971] Wed, 08 November 2017 17:52 Go to previous messageGo to next message
Yup, the C/C++ and Java IDE always fails in this manner each time I try. I there are three main error message every time:
ERROR: org.eclipse.equinox.p2.engine code=0 session context was:(profile=C__Users_HP_eclipse_java-oxygen6_eclipse, phase=org.eclipse.equinox.internal.p2.engine.phases.CheckTrust, operand=, action=).
ERROR: org.eclipse.equinox.p2.engine code=0 Error reading signed content.
Best Regards
Muneeb Khan
~ murk3000
Re: Eclipse Error [message #1775977 is a reply to message #1775976] Wed, 08 November 2017 18:15 Go to previous message
Alright so I fixed the problem. Apparently the file hadn't downloaded at all. So what you had to do was delete all eclipse folders (.p2, .eclipse and eclispe) and then with a good internet connection reinstall the IDE you want.
Thank you for you help! I wouldn't have realized I was missing files without you.
Best Regards
Muneeb Khan
~ murk3000
Previous Topic:Eclipse Opening Problem
Next Topic:papyrus extension points
Current Time: Tue Apr 16 21:26:15 GMT 2024
Powered by FUDForum. Page generated in 0.61200 seconds
