Re: Import Diagram in another Viewpoint in Same .Odesign file. [message #1850149 is a reply to message #1850127] |
Fri, 18 February 2022 01:21  |
On the viewpoint, where you want to load a diagram description from another viewpoint file, you first need to select the contextual action "Load resource" and load the .odesign file you are interested in. Then, on your current viewpoint, you add a "Diagram import" (from the contextual menu "New Import"). From this element, on the General tab of the properties view, you will find a field "Imported diagram" where you will be able to select the diagram description from the other file (because it was loaded).
Steve
Steve Monnier - Obeo Canada
FUDForum. Page generated in 0.02506 seconds
