Home » Eclipse Projects » Sirius » Import Diagram in another Viewpoint in Same .Odesign file.
Import Diagram in another Viewpoint in Same .Odesign file. [message #1775561] Wed, 01 November 2017 10:00 Go to next message
Yash Khatri is currently offline Yash KhatriFriend
Member
I have a .odesign file where I have 4 diagrams defined under one view point. Now, I want to have separate viewpoints for individual diagrams and one super viewpoint that have all the diagrams.
Steps:
1. I have created all 4 diagrams in one viewpoint1.
2. Created another viewpoint (viewpoint2) and imported diagram from viewpoint1.
3. Followed step 2 for remaining diagrams.
Problem:
I can see that the diagram is imported from viewpoint1 into other viewpoints in .odesign file but, when I am creating a new modeling project, new model, selecting the viewpoint2 (that contains the imported diagram from viewpoint1). No tools are being shown in the palette.
Is it a bug? All the tools that were created for that specific diagram should be available here in the palette.
Re: Import Diagram in another Viewpoint in Same .Odesign file. [message #1775619 is a reply to message #1775561] Thu, 02 November 2017 09:15 Go to previous messageGo to next message
Pierre-Charles David is currently offline Pierre-Charles DavidFriend
Yes, it looks like a bug. Can you open a bugzilla issue to track it please? (https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Sirius)
Thanks.
Pierre-Charles David - Obeo
Re: Import Diagram in another Viewpoint in Same .Odesign file. [message #1775626 is a reply to message #1775619] Thu, 02 November 2017 10:26 Go to previous messageGo to next message
Member
Done. https://bugs.eclipse.org/bugs/show_bug.cgi?id=526752
-Yash
Re: Import Diagram in another Viewpoint in Same .Odesign file. [message #1850127 is a reply to message #1775561] Thu, 17 February 2022 06:39 Go to previous messageGo to next message
aloe liu is currently offline aloe liuFriend
hello,I want to konw how you import diagram in another viewpoint .odesign file?
Re: Import Diagram in another Viewpoint in Same .Odesign file. [message #1850149 is a reply to message #1850127] Fri, 18 February 2022 01:21 Go to previous message
Steve Monnier is currently offline Steve MonnierFriend
On the viewpoint, where you want to load a diagram description from another viewpoint file, you first need to select the contextual action "Load resource" and load the .odesign file you are interested in. Then, on your current viewpoint, you add a "Diagram import" (from the contextual menu "New Import"). From this element, on the General tab of the properties view, you will find a field "Imported diagram" where you will be able to select the diagram description from the other file (because it was loaded).
Steve
Steve Monnier - Obeo Canada
Previous Topic: SiriusCon 2022 - Call for Papers is now open!
Next Topic:Change save options
Current Time: Sat Mar 25 15:35:12 GMT 2023
Powered by FUDForum. Page generated in 0.01942 seconds
