Home » Eclipse Projects » BPMN 2.0 Modeler » Create Elements Programmatically
Create Elements Programmatically [message #1775421] Mon, 30 October 2017 07:39 Go to next message
Umut Kazan is currently offline Umut KazanFriend
I want to create my elements programmatically. I have a Unity(C#) editor and when user drag and drop an element such as start event in Unity editor, text should be sent by socket to the my bpmn editor and start event should be created. How can i achieve this?
Umut Kazan
[Updated on: Mon, 30 October 2017 07:40]
Report message to a moderator
Re: Create Elements Programmatically [message #1775660 is a reply to message #1775421] Thu, 02 November 2017 21:01 Go to previous messageGo to next message
Ralph Soika is currently offline Ralph SoikaFriend
I am not sure if this is possible, because Eclipse BPMN2 is based on EMF and the Eclipse Graphiti project. The editor is based on visual editing only (I think). So even when you change the underlying BPMN file with your data send from your Editor this will not effect the graphical representation. This would only happen if you change EMF Object structure (by adding new or modifying existing objects).
So if you just change the bpmn file you need to close and reopen the editor.
Re: Create Elements Programmatically [message #1775661 is a reply to message #1775660] Thu, 02 November 2017 21:04 Go to previous messageGo to next message
Mybe you can take a look at this tutorial pages:
https://wiki.eclipse.org/BPMN2-Modeler/DeveloperTutorials/ModelExtension
https://wiki.eclipse.org/BPMN2-Modeler/DeveloperTutorials/Adapters
Ralph
Re: Create Elements Programmatically [message #1775851 is a reply to message #1775661] Tue, 07 November 2017 09:23 Go to previous messageGo to next message
Thank you Ralph,
I have figured how to do it :)
Umut
Re: Create Elements Programmatically [message #1776722 is a reply to message #1775851] Mon, 20 November 2017 18:28 Go to previous messageGo to next message
Great! Ban you share a code snippet how you solved it?
Re: Create Elements Programmatically [message #1776756 is a reply to message #1776722] Tue, 21 November 2017 08:46 Go to previous message
                IWorkbench wb = PlatformUI.getWorkbench();
		IWorkbenchWindow window = wb.getActiveWorkbenchWindow();
		IWorkbenchPage page = window.getActivePage();
		IEditorPart editor = page.getActiveEditor();
		final SbpMultiPageEditor sbpMPE = (SbpMultiPageEditor) editor;
		IFeature createTask = (IFeature) getCreateFeature(shape.getType(), sbpMPE.getDesignEditor().getDiagramTypeProvider().getFeatureProvider());
		CreateContext createCon = new CreateContext();
		createCon.setX(shape.getX());
		createCon.setY(shape.getY());
		createCon.setHeight(-1);
		createCon.setWidth(-1);
		createCon.setTargetContainer(sbpMPE.getDesignEditor().getDiagramTypeProvider().getFeatureProvider().getDiagramTypeProvider().getDiagram());
		AbstractCreateFlowElementFeature createTaskFeature = (AbstractCreateFlowElementFeature) createTask;
		FlowElement element = (FlowElement) createBusinessObject(createCon, createTaskFeature.getBusinessObjectClass());
		element.setId(shape.getId());
		element.setName(shape.getName());
		if (element != null)
			try
				final ModelHandler handler = ModelHandler.getInstance(sbpMPE.getDesignEditor().getDiagramTypeProvider().getFeatureProvider()
				final FlowElement finalElement = element;
				// System.out.println(finalElement);
				// handleProperties(finalElement);
				final CreateContext finalCreateCon = createCon;
				EditorUtil.ExecuteInTransactionalDomain(new IExecutable()
					public void execute()
						handler.addFlowElement(BusinessObjectUtil.getBusinessObjectForPictogramElement(finalCreateCon.getTargetContainer()),
								finalElement);
						AddContext addContext = new AddContext(finalCreateCon, finalElement);
						sbpMPE.getDesignEditor().getDiagramTypeProvider().getFeatureProvider().addIfPossible(addContext);
				}, sbpMPE.getDesignEditor().getEditingDomain());
			catch (IOException e)
				Activator.logError(e);
I don't know if this will help anybody because there are several custom methods and class but the idea is create the context and business object(flow element). Then add it to editor.
Umut
Previous Topic:I want to add an customxml editor.
Next Topic:Creating more than one extension
Current Time: Thu Feb 20 18:09:46 GMT 2020
Powered by FUDForum. Page generated in 0.01872 seconds
