Home » Archived » Eclipse SmartHome » HTTP ERROR 404
HTTP ERROR 404 [message #1775298] Fri, 27 October 2017 06:57 Go to next message
Hi. I have a problem about your guide. I did everything which written in the following tutorial
https://www.eclipse.org/smarthome/documentation/development/ide.html
program is runnig but in the end forwarding to this page http://localhost:8080/paperui/index.html
give as a response :
HTTP ERROR 404
Problem accessing /paperui/index.html. Reason:
ProxyServlet: /paperui/index.html
Powered by Jetty:// 9.3.14.v20161028
I can't find the solution of the problem, please give me the right direction to find out the problem.
thanks in advance
Re: HTTP ERROR 404 [message #1775377 is a reply to message #1775298] Sat, 28 October 2017 15:16 Go to previous messageGo to next message
I am having the same issue - looks like I am having an issue with the 'Launch PaperUI Setup' step:
Performing Launch PaperUI Setup
Execute Debug Command
Synchronizing Resources...
Updating Git status for repository smarthome
Updating Git status for repository smarthome:   0% (  57/5740)
[INFO] Scanning for projects...
[ERROR] Internal error: java.lang.RuntimeException: Could not resolve target platform specification artifact org.eclipse.smarthome:targetplatform:target:smarthome:0.9.0-SNAPSHOT -> [Help 1]
Re: HTTP ERROR 404 [message #1775456 is a reply to message #1775377] Mon, 30 October 2017 07:27 Go to previous message
This is indeed a known problem, see also https://www.eclipse.org/forums/index.php?t=msg&th=1089731&goto=1775455&#msg_1775455.
Please run a "mvn clean install" from the command line and the Paper UI should be all fine afterwards!
Previous Topic:NextPreviousType/UpDownType
Next Topic:Stuck on finalizing installation
Current Time: Fri Jun 13 07:05:29 EDT 2025
Powered by FUDForum. Page generated in 0.04576 seconds
