Home » Newcomers » Newcomers » Null Pointer during Indexing of documentation (While trying to access documentation for the first time after recent install of STS)
Null Pointer during Indexing of documentation [message #1775171] Wed, 25 October 2017 18:02
Ron Wheeler is currently offline Ron WheelerFriend
This error repeated many times a minute while accessing documentation.
Documentation seemed to be there while this was going on.
The workspace folder has been in use through many upgrades of the Eclipse/STS system so there might be stuff in the configuration setting that is inconsistent.
Guesses:
Configurations created by an earlier version may contain references to options not installed in a later version.
Probably Eclipse making assumptions about files being present because the feature is referenced in a configuration file.
Upgrading using the software Update process is not working very well and it is less trouble to just forget the current version and install a new complete distribution and reapply the optional components.
Eclipse needs to protect itself from lies in the configuration files (or make upgrades work better).
eclipse.buildId=3.9.1.201710111105-RELEASE-e47
java.version=1.8.0_144
at org.apache.lucene.index.SegmentInfos$FindSegmentsFile.run(SegmentInfos.java:665)
at org.apache.lucene.index.StandardDirectoryReader.open(StandardDirectoryReader.java:76)
at org.apache.lucene.index.DirectoryReader.open(DirectoryReader.java:63)
at org.eclipse.help.internal.search.SearchIndex.<init>(SearchIndex.java:202)
at org.eclipse.help.internal.search.SearchIndex.<init>(SearchIndex.java:156)
at org.eclipse.help.internal.search.SearchIndexWithIndexingProgress.<init>(SearchIndexWithIndexingProgress.java:24)
at org.eclipse.help.internal.search.LocalSearchManager.getIndex(LocalSearchManager.java:183)
at org.eclipse.help.internal.search.LocalSearchManager.search(LocalSearchManager.java:548)
at org.eclipse.help.internal.search.SearchManager.searchLocal(SearchManager.java:105)
at org.eclipse.help.internal.search.SearchManager.search(SearchManager.java:96)
at org.eclipse.help.internal.search.SearchProgressMonitor.lambda$0(SearchProgressMonitor.java:171)
at java.lang.Thread.run(Thread.java:748)
Previous Topic:Navigate, Matching character doesn't works in JSP files
Next Topic:An error has occurred (MAC)
Current Time: Fri Aug 07 10:24:07 GMT 2020
Powered by FUDForum. Page generated in 0.02845 seconds
