Home » Eclipse Projects » Eclipse 4 » Remove Perspectives
Remove Perspectives [message #1775066] Tue, 24 October 2017 09:51 Go to next message
philipp huebner is currently offline philipp huebnerFriend
Member
Hi together,
we migrated a e3x app to e4, using compatibility layer. We have a licencing system which hides features from the user via activities, patterns, property tester.
And removing non-user perspectives from the Perspective Registry programmaticaly. This is broken....
Doe's anybody know a way to do that now?
Re: Remove Perspectives [message #1775074 is a reply to message #1775066] Tue, 24 October 2017 10:20 Go to previous messageGo to next message
Member
The problem is this if:
public void deletePerspective(IPerspectiveDescriptor toDelete) {
PerspectiveDescriptor perspective = (PerspectiveDescriptor) toDelete;
if (perspective.isPredefined())
return;
descriptors.remove(perspective.getId());
removeSnippet(application, perspective.getId());
in the perspective Registry. Don't know why the heck this was done... Is it possible to manipulate the DI system in away your inhereited class is used?
Re: Remove Perspectives [message #1775086 is a reply to message #1775074] Tue, 24 October 2017 12:57 Go to previous messageGo to next message
Erdal Karaca is currently offline Erdal KaracaFriend
I ended up using the XSLT transforms hook to remove/filter unwanted UI elements that activities could not hide, see:
https://wiki.eclipse.org/Equinox_Transforms
philipp huebner wrote on Tue, 24 October 2017 12:20
return;
Re: Remove Perspectives [message #1775089 is a reply to message #1775086] Tue, 24 October 2017 13:14 Go to previous messageGo to next message
Member
This is a fucking joke, or?
Re: Remove Perspectives [message #1775102 is a reply to message #1775086] Tue, 24 October 2017 14:54 Go to previous messageGo to next message
Anton Nogaller is currently offline Anton NogallerFriend
Hello Erdal, your link is quite old, the CVS references from it are not available anymore.
In which file does the Transformer code belong?
Re: Remove Perspectives [message #1775145 is a reply to message #1775102] Wed, 25 October 2017 09:32 Go to previous message
You can consume the transforms hook from the main update site, for example, when using neon:
http://download.eclipse.org/releases/neon
Check the "Equinox Target Components"!
Anton Nogaller wrote on Tue, 24 October 2017 16:54
Previous Topic:Moving a part opened by Eclipse's Open View menu
Next Topic:Implement plugin/feature toggle
Current Time: Wed Oct 21 13:40:44 GMT 2020
Powered by FUDForum. Page generated in 0.02506 seconds
