Home » Eclipse Projects » Memory Analyzer » does MAT work on java 9?(question to see if errors noticed in java 9 vm are expected)
does MAT work on java 9? [message #1775034] Mon, 23 October 2017 15:22 Go to next message
Hi guys,
Thanks for the great tool!
I was trying to see if Eclipse MAT (1.7.0) works with java 9. I set the `-vm /usr/local/java/jdk9/bin/java` option in the MemoryAnalyzer.ini and it failed with a bunch of errors (attached). It gives a final message to resolve something in `config.ini` but it has way too much text to easily identify the fix. Would appreciate if someone can guide me here?
Thanks!
Re: does MAT work on java 9? [message #1775641 is a reply to message #1775034] Thu, 02 November 2017 09:54 Go to previous message
I haven't done much work on this so am not surprised there are problems, as stand alone Memory Analyzer is based on Eclipse 4.5 (Mars).
Some things to try:
  1. Use JDK 8 instead
  2. Install Memory Analyzer into Eclipse 4.7.1a
  3. See if https://wiki.eclipse.org/Configure_Eclipse_for_Java_9 offers any ideas
The latest nightly builds have an update to cope with the Java 9 String format in Java 9 heap dumps.
http://download.eclipse.org/mat/snapshots/update-site/
https://www.eclipse.org/mat/snapshotBuilds.php
Previous Topic:ParseHeapdump.sh throws error
Next Topic:Memory Analyzer 1.7.0 Released
Current Time: Sun Nov 02 02:49:42 EST 2025
Powered by FUDForum. Page generated in 0.03769 seconds
