Home » Newcomers » Newcomers » Cannot update Eclipse: missing repository for 2 google inject items(No repository found containing: osgi.bundle,com.google.inject,3.0.0.v201605172100)
Cannot update Eclipse: missing repository for 2 google inject items [message #1774621] Wed, 18 October 2017 00:35 Go to next message
I have been getting the error msgs below for the past several weeks when I click on the update notification. The bundle must contain 20 line items/folders, but the missing repository error msg blocks all the updates, not just those relying on the com.google osgi's repository.
I was hoping that many people would be getting the same error msg, and that it would be fixed after a few days. So far that is not the case, so I have posted it here in the newby forum.
Thanks/Cheerss,
Marc
Eclipse version:
Version: Oxygen Release (4.7.0)
Build id: 20170620-1800
Error message:
An error occurred while collecting items to be installed
session context was:(profile=C__Users_marcs_java-oxygen2_eclipse, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
No repository found containing: osgi.bundle,com.google.inject.multibindings,3.0.0.v201605172100
Re: Cannot update Eclipse: missing repository for 2 google inject items [message #1774628 is a reply to message #1774621] Wed, 18 October 2017 06:55 Go to previous messageGo to next message
Those bundles are in Neon and Oxygen update sites, e.g., in http://download.eclipse.org/releases/oxygen
Is that enabled in Window -> Preferences -> Install/Update -> Available Software Sites?
Re: Cannot update Eclipse: missing repository for 2 google inject items [message #1777686 is a reply to message #1774621] Fri, 01 December 2017 14:35 Go to previous messageGo to next message
This is what I did to fix it..
  1. Go into Help --> Install New Software
  2. Deselect the 'Contact all update sites during install to find required software (this might be optional.. haven't tested)
  3. Select the Oxygen (or your version of eclipse) site from the Work With.. drop-down
  4. Go through each section and each item and look for the update (looks like refresh) icon beside it.
  5. if it has an update icon beside it, select it.. there will be a few
  6. Install the checked items
Once this is done, you can do a normal update and things will hopefully be back to normal.
Re: Cannot update Eclipse: missing repository for 2 google inject items [message #1779072 is a reply to message #1777686] Tue, 02 January 2018 03:21 Go to previous messageGo to next message
I had this problem as well. I have updated all other features / plugins / etc .. are are now only left with the following that cannot be updated:
Code Recommenders for Java Developers 2.5.0.v20171201-1623
Code Recommenders Mylyn Integration 2.5.0.v20171201-1623
session context was:(profile=C__eclipse-jee-oxygen_eclipse, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
The "Code Recommenders" is using the the following URL in the "Available Software Sites":
http://download.eclipse.org/recommenders/updates/stable/
.. and if you look at the plugins dir:
http://download.eclipse.org/recommenders/updates/stable/?dir=plugins
.. my understanding is that, It shows that the JARs are there ( at least on the meta-data ):
com.google.inject.source_3.0.0.v201605172100.jar
com.google.inject.multibindings_3.0.0.v201605172100.jar
... so should have NOT errored out. Just not sure what the "osgi.bundle," means in front of "com.google.inject,3.0.0.v201605172100"
What I did as a workaround it was to do what Stephen did above. Specifically, that is to deselect the "Contact all update sites during install to find required software" when installing the update for "Code Recommenders".
Re: Cannot update Eclipse: missing repository for 2 google inject items [message #1785278 is a reply to message #1774628] Thu, 12 April 2018 00:32 Go to previous messageGo to next message
Sorry it has taken me so long to respond, guess I need to enable ECF notifications
Yes that repository is there
Re: Cannot update Eclipse: missing repository for 2 google inject items [message #1785279 is a reply to message #1777686] Thu, 12 April 2018 01:34 Go to previous messageGo to next message
This worked for me too! Started getting same error message with Oxygen April 2018 release, and that is what brought me back to the forum.
Thanks Stephen!
Marc
Re: Cannot update Eclipse: missing repository for 2 google inject items [message #1790505 is a reply to message #1774621] Tue, 12 June 2018 03:20 Go to previous messageGo to next message
I had problems updating recommenders all since Oxygen 3A.
What I did now for the update 2.5.2 -> 2.5.3 is to uninstall recommenders from the marketplace "Installed" tab, restarted eclipse, got the notification that recommenders is missing, installed it again and afterwards the update went through.
Re: Cannot update Eclipse: missing repository for 2 google inject items [message #1790579 is a reply to message #1790505] Wed, 13 June 2018 08:32 Go to previous message
I tried Frank's solution for the Recommenders update June2018.
It did not work for me, but Stephen's original answer with respect to <--(wrt) osgi bundles at google problem, did work again wrt the Recommenders update
Previous Topic:can not install off-line
Next Topic:How do I Localizing Text in Column Headings of table in BIRT report?
Current Time: Wed Feb 19 03:19:24 GMT 2025
Powered by FUDForum. Page generated in 0.08848 seconds
