Cannot launch junit plugin test in oxygen because of java 9 support [message #1774382] |
Fri, 13 October 2017 14:13  |
Arnaud MERGEY Messages: 241 Registered: March 2010 Location: France |
With java 9 support it is not possible anymore to launch Junit Plugin Tests (Junit4 and openJDK 8)
exception above.
Everyone in my team has same issue, so we remove java 9 support from eclipse, but with oxygen SR1.a installation the issue comes back
Is there any way to workaround this ?
java.lang.AbstractMethodError: org.eclipse.jdt.internal.junit4.runner.JUnit4TestLoader.loadTests([Ljava/lang/Class;Ljava/lang/String;[Ljava/lang/String;Lorg/eclipse/jdt/internal/junit/runner/RemoteTestRunner;)[Lorg/eclipse/jdt/internal/junit/runner/ITestReference;
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:444)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:678)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:382)
at org.eclipse.pde.internal.junit.runtime.RemotePluginTestRunner.main(RemotePluginTestRunner.java:181)
at org.eclipse.pde.internal.junit.runtime.CoreTestApplication.run(CoreTestApplication.java:24)
at org.eclipse.equinox.internal.app.EclipseAppContainer.callMethodWithException(EclipseAppContainer.java:587)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:198)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:653)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:590)
at org.eclipse.equinox.launcher.Main.run(Main.java:1499)
at org.eclipse.equinox.launcher.Main.main(Main.java:1472)
[Updated on: Fri, 13 October 2017 14:22] Report message to a moderator
Re: Cannot launch junit plugin test in oxygen because of java 9 support [message #1774398 is a reply to message #1774397] |
Fri, 13 October 2017 16:53   |
I think it is the opposite, I am running a new build (Eclipse Oxygen SR1a) with Junit 5 support an my target have org.eclipse.jdt.junit.runtime
(and no org.eclipse.jdt.junit4.runtime) from an old build without JUnit 5 support (RAP Oxygen), but it probably leads to issues too.
So adding Junit5 support in Eclipse Oxygen SR1a probably broke RAP development
environment, and it is probably the reason why I had dependencies error when I
tried to upgrade my target platform to RAP Oxygen SR1 and Equinox Oxygen SR1a
(there is no RAP Oxygen SR1a but they probably should have delivered a version with Junit5 support as well)
[Updated on: Fri, 13 October 2017 17:06] Report message to a moderator
FUDForum. Page generated in 0.03129 seconds
