Home » Eclipse Projects » Sirius » BIRT and Sirius
BIRT and Sirius [message #1774358] Fri, 13 October 2017 09:20 Go to next message
Leonid Novikov is currently offline Leonid NovikovFriend
Whether there are ready decisions on usage BIRT for generation of reports from models, generated with use Sirius?
If is not present:
What parts of the source code are responsible for extraction from a file *.aird information of the image of the chart and chart display in a graphic editor?
Where it is possible to read about it?
Thank you very much
lnew@yandex.ru
[Updated on: Tue, 17 October 2017 15:49]
Report message to a moderator
Re: BIRT and Sirius [message #1774505 is a reply to message #1774358] Mon, 16 October 2017 14:53 Go to previous messageGo to next message
Maxime Porhel is currently offline Maxime PorhelFriend
Could review your first question and give us the meaning of "сформипованных" ?
You could look into org.eclipse.sirius.ui.tools.api.actions.export.ExportAction.ExportAction and/or export/exportWithResult methods from org.eclipse.sirius.ui.business.api.dialect.DialectUIManager.INSTANCE
Maxime Porhel - Obeo
Re: BIRT and Sirius [message #1774594 is a reply to message #1774505] Tue, 17 October 2017 15:47 Go to previous messageGo to next message
Thank you very much!
Russian word has corrected. Sorry!
I have generated report BIRT from metamodel Ecore (files .ecore and.aird), containing all necessary text information, almost standard way, having chosen DataSource XML.
It is necessary to insert diagrammes.
Once again, thanks.
Re: BIRT and Sirius [message #1774632 is a reply to message #1774594] Wed, 18 October 2017 07:12 Go to previous messageGo to next message
Hi Leonid,
There is no current integration for Birt provided by Sirius.
The API to export images from a Sirius session are org.eclipse.sirius.ui.tools.api.actions.export.ExportAction.ExportAction and/or export/exportWithResult methods from org.eclipse.sirius.ui.business.api.dialect.DialectUIManager.
Note that you might also take a look to org.eclipse.sirius.ui.tools.internal.actions.export.ExportRepresentationsFromFileAction (https://git.eclipse.org/c/sirius/org.eclipse.sirius.git/tree/plugins/org.eclipse.sirius.ui/src/org/eclipse/sirius/ui/tools/internal/actions/export/ExportRepresentationsFromFileAction.java) to see how to export all representations from the aird if is not loaded.
Re: BIRT and Sirius [message #1774640 is a reply to message #1774632] Wed, 18 October 2017 08:20 Go to previous message
Thanks Maxime!
Previous Topic:Copy & Past Context Menu in Tree Description
Next Topic:Pane Based Selection Wizard
Current Time: Fri Jul 30 11:51:14 GMT 2021
Powered by FUDForum. Page generated in 0.02364 seconds
