[Databinding] keeping the model in sync with validation [message #332894] |
Wed, 12 November 2008 20:15  |
I'm using a DataBindingContext to create a simple binding a SWT Text and
a String WritableValue. The widget is hosted in a WizardPage and I am
using WizardPageSupport to track the validation.
My validation requirement is simple - the string should not be empty.
Using examples from snippets, I first accomplished this by using an
UpdateValueStrategy with a validateAfterGet IValidator. However, I
discovered that using this type of validation allows the UI and the
model to get out of sync. For example, if the widget has a single
character "A" and I delete it, the validation will cause the update to
fail and the model will retain the value "A" despite the widget now
being empty. I understand this behavior, since there are cases where
the model cannot accept the value in the UI at all. But I would prefer
they stay in sync in this case.
So my second attempt (which seems to be working) was to add a
MultiValidator to the DataBindingContext that validates the model
(WritableValue) directly. Is this the proper way to do it?
MultiValidator's name and javadoc do not imply that this use case was
envisioned.
Will
Re: [Databinding] keeping the model in sync with validation [message #332974 is a reply to message #332957] |
Mon, 17 November 2008 11:26  |
I think he wants the model and target to stay in sync even if there is a
validation error.
>> discovered that using this type of validation allows the UI and the model
>> to get out of sync. For example, if the widget has a single character "A"
>> and I delete it, the validation will cause the update to fail and the
>> model will retain the value "A" despite the widget now being empty. I
>> understand this behavior, since there are cases where the model cannot
>> accept the value in the UI at all. But I would prefer they stay in sync in
>> this case.
> I am confused - can the string be empty or not? When a binding has a
> validation error, the observable values are out of sync (almost by
> definition).
> Is maybe what you want that the model is not updated on every key press, but
> on FocusOut, or perhaps when the user presses Next/Finish?
> Boris
FUDForum. Page generated in 0.03143 seconds
