Home » Eclipse Projects » Eclipse 4 » Hook that GUI has completely rendered(Run E4 based code after the whole application has started and the GUI has completely rendered)
Hook that GUI has completely rendered [message #1773886] Fri, 06 October 2017 06:23 Go to next message
M V is currently offline M VFriend
Member
i have an E3/E4 mixed application with compatibility layer. I would like to run E4 based code after the whole application has started and the GUI has completely rendered.
- I tried to use a LifeCycle Manager but all annotations are to early for it.
- I tried it in the ApplicationWorkbenchWindowAdvisor but there I have no access to the EModelService or MApplication.
- As a processor extension I tried it too, but this is also too early the same for an Addon in the Application.e4xmi.
Is there maybe a listener or something similar where I can hook my code?
thank you
crosspost Stackoverflow
error configuration/1507308260387.log [message #1773933 is a reply to message #1773886] Fri, 06 October 2017 17:06 Go to previous messageGo to next message
sonu sace is currently offline sonu saceFriend
can anybody help me how to resolve it. I am totally new and even don't know much about eclips
Re: error configuration/1507308260387.log [message #1774149 is a reply to message #1773933] Wed, 11 October 2017 03:44 Go to previous message
Dirk Fauth is currently offline Dirk FauthFriend
Check the linked stackoverflow post. The answer is there.
Previous Topic:Handled Menu Item Icons
Next Topic:How to get curved (blue) tabs when running under e4?
Current Time: Wed Oct 21 17:09:54 GMT 2020
Powered by FUDForum. Page generated in 0.01684 seconds
