| Birt Report not dispaying after updating the stored procedure logic [message #1773827] |
Thu, 05 October 2017 03:43  |
Hi Team,
I am new to birt report engine, as part of my project there is an existing report which is getting in generated using birt report engine.
Now there is a requirement to remove and add new fields. as part of this change we need to modify the stored procedure to get the additional columns and records.
We have modified the stored procedure to get the additional columns and new records by adding some logic in stored procedure query WHERE clause . Also we updated the template file as-well.
When we run the report it displays all the new columns which are required, but it is not displaying the new records and new column values which are fetched in stored procedure query using new WHERE conditions.
Could you please guide what needs to done?
FUDForum. Page generated in 0.60617 seconds
