Home » Eclipse Projects » BIRT » Birt Report not getting the updated Stored Procedure output(records)(Birt Report not getting the updated Stored Procedure output(records))
Birt Report not getting the updated Stored Procedure output(records) [message #1773773] Wed, 04 October 2017 13:40
Rajesh Ravindran is currently offline Rajesh RavindranFriend
Hi Team,
I am new to birt report engine, as part of my project there is an existing report which is getting in generated using birt report engine. Now there is a requirement to remove and add new fields. In the same requirment, we need to modify the stored procedure the get the additional columns and records.
We have modified the stored procedure to get the additional columsn and records . At the same time we updated the template as-well.
When we run the report it displays all the new columns which are required, but it is not displaying the new records which are fetched in stored procedure query using new join conditions.
Could you please guide what needs to done?
Previous Topic:How to use a computed column in the where clause of the query
Next Topic:Table with N to M conditon
Current Time: Sat Aug 08 10:12:29 GMT 2020
Powered by FUDForum. Page generated in 0.01951 seconds
