Home » Eclipse Projects » NatTable » Add new row header
Add new row header [message #1773640] Mon, 02 October 2017 06:56 Go to next message
cenk Mising name is currently offline cenk Mising nameFriend
Is it possible Add new row headers. Is there any examples for this.
Re: Add new row header [message #1773641 is a reply to message #1773640] Mon, 02 October 2017 07:11 Go to previous messageGo to next message
Dirk Fauth is currently offline Dirk FauthFriend
What do you consider to be a new row header? In theory it is the same as for the body region. The only thing to consider is the dimensional dependency.
It is not clear to me what you are trying to achieve. The layer concepts are the same in every region, despite the dimensional dependency.
Re: Add new row header [message #1773656 is a reply to message #1773641] Mon, 02 October 2017 12:33 Go to previous messageGo to next message
I can solved my problem. I found ScrollableRowHeaderExample.java. And I modified this source and I added check box on second row header. But I can't make editable check box on row header.
Our test code is below. How can I editable check box. Thank you for your help
package multiheaderrow;
import java.util.HashMap;
import java.util.Map;
import org.eclipse.nebula.widgets.nattable.NatTable;
import org.eclipse.nebula.widgets.nattable.config.AbstractRegistryConfiguration;
import org.eclipse.nebula.widgets.nattable.config.CellConfigAttributes;
import org.eclipse.nebula.widgets.nattable.config.DefaultNatTableStyleConfiguration;
import org.eclipse.nebula.widgets.nattable.config.IConfigRegistry;
import org.eclipse.nebula.widgets.nattable.config.IEditableRule;
import org.eclipse.nebula.widgets.nattable.data.IColumnPropertyAccessor;
import org.eclipse.nebula.widgets.nattable.data.IDataProvider;
import org.eclipse.nebula.widgets.nattable.data.IRowDataProvider;
import org.eclipse.nebula.widgets.nattable.data.ListDataProvider;
import org.eclipse.nebula.widgets.nattable.data.ReflectiveColumnPropertyAccessor;
import org.eclipse.nebula.widgets.nattable.edit.EditConfigAttributes;
import org.eclipse.nebula.widgets.nattable.edit.action.ToggleCheckBoxColumnAction;
import org.eclipse.nebula.widgets.nattable.edit.editor.CheckBoxCellEditor;
import org.eclipse.nebula.widgets.nattable.examples.AbstractNatExample;
import org.eclipse.nebula.widgets.nattable.examples.data.person.PersonService;
import org.eclipse.nebula.widgets.nattable.examples.runner.StandaloneNatExampleRunner;
import org.eclipse.nebula.widgets.nattable.grid.GridRegion;
import org.eclipse.nebula.widgets.nattable.grid.data.DefaultColumnHeaderDataProvider;
import org.eclipse.nebula.widgets.nattable.grid.data.DefaultCornerDataProvider;
import org.eclipse.nebula.widgets.nattable.grid.data.DefaultRowHeaderDataProvider;
import org.eclipse.nebula.widgets.nattable.grid.layer.ColumnHeaderLayer;
import org.eclipse.nebula.widgets.nattable.grid.layer.CornerLayer;
import org.eclipse.nebula.widgets.nattable.grid.layer.DefaultColumnHeaderDataLayer;
import org.eclipse.nebula.widgets.nattable.grid.layer.DefaultRowHeaderDataLayer;
import org.eclipse.nebula.widgets.nattable.grid.layer.GridLayer;
import org.eclipse.nebula.widgets.nattable.grid.layer.RowHeaderLayer;
import org.eclipse.nebula.widgets.nattable.layer.AbstractLayer;
import org.eclipse.nebula.widgets.nattable.layer.CompositeLayer;
import org.eclipse.nebula.widgets.nattable.layer.DataLayer;
import org.eclipse.nebula.widgets.nattable.layer.ILayer;
import org.eclipse.nebula.widgets.nattable.layer.LabelStack;
import org.eclipse.nebula.widgets.nattable.layer.cell.CellOverrideLabelAccumulator;
import org.eclipse.nebula.widgets.nattable.layer.cell.ColumnOverrideLabelAccumulator;
import org.eclipse.nebula.widgets.nattable.painter.IOverlayPainter;
import org.eclipse.nebula.widgets.nattable.painter.cell.CheckBoxPainter;
import org.eclipse.nebula.widgets.nattable.painter.cell.ICellPainter;
import org.eclipse.nebula.widgets.nattable.painter.cell.ImagePainter;
import org.eclipse.nebula.widgets.nattable.painter.cell.decorator.PaddingDecorator;
import org.eclipse.nebula.widgets.nattable.painter.layer.CellLayerPainter;
import org.eclipse.nebula.widgets.nattable.selection.SelectionLayer;
import org.eclipse.nebula.widgets.nattable.selection.SelectionLayerPainter;
import org.eclipse.nebula.widgets.nattable.style.DisplayMode;
import org.eclipse.nebula.widgets.nattable.ui.NatEventData;
import org.eclipse.nebula.widgets.nattable.ui.action.IDragMode;
import org.eclipse.nebula.widgets.nattable.ui.action.IMouseAction;
import org.eclipse.nebula.widgets.nattable.ui.binding.UiBindingRegistry;
import org.eclipse.nebula.widgets.nattable.ui.matcher.CellPainterMouseEventMatcher;
import org.eclipse.nebula.widgets.nattable.ui.matcher.MouseEventMatcher;
import org.eclipse.nebula.widgets.nattable.util.ClientAreaAdapter;
import org.eclipse.nebula.widgets.nattable.util.GUIHelper;
import org.eclipse.nebula.widgets.nattable.viewport.SliderScroller;
import org.eclipse.nebula.widgets.nattable.viewport.ViewportLayer;
import org.eclipse.nebula.widgets.nattable.viewport.command.RecalculateScrollBarsCommand;
import org.eclipse.swt.SWT;
import org.eclipse.swt.events.MouseEvent;
import org.eclipse.swt.graphics.Color;
import org.eclipse.swt.graphics.GC;
import org.eclipse.swt.graphics.Point;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Control;
import org.eclipse.swt.widgets.Slider;
public class ScrollableRowHeaderExample_Test extends AbstractNatExample {
	private DataLayer rowDataLayer;
    public static void main(String[] args) throws Exception {
        StandaloneNatExampleRunner.run(600, 400, new ScrollableRowHeaderExample_Test());
    public String getDescription() {
        return "This example shows a scrollable row header.";
    public Control createExampleControl(Composite parent) {
        // property names of the Person class
        String[] propertyNames = { "firstName", "lastName", "gender", "married", "birthday" };
        // mapping from property to label, needed for column header labels
        Map propertyToLabelMap = new HashMap<>();
        propertyToLabelMap.put("firstName", "Firstname");
        propertyToLabelMap.put("lastName", "Lastname");
        propertyToLabelMap.put("gender", "Gender");
        propertyToLabelMap.put("married", "Married");
        propertyToLabelMap.put("birthday", "Birthday");
        IColumnPropertyAccessor columnPropertyAccessor =
                new ReflectiveColumnPropertyAccessor<>(propertyNames);
        IDataProvider bodyDataProvider =
                new ListDataProvider<>(PersonService.getPersons(10), columnPropertyAccessor);
        DataLayer bodyDataLayer = new DataLayer(bodyDataProvider);
        SelectionLayer selectionLayer = new SelectionLayer(bodyDataLayer);
        ViewportLayer viewportLayer = new ViewportLayer(selectionLayer);
        rowDataLayer = new DataLayer(new IRowDataProvider() {
            public void setDataValue(int columnIndex, int rowIndex, Object newValue) {
            public int getRowCount() {
                return bodyDataProvider.getRowCount();
            public Object getDataValue(int columnIndex, int rowIndex) {
            	return false;
            public int getColumnCount() {
                return 1;
			public Object getRowObject(int rowIndex) {
				// TODO Auto-generated method stub
				return Integer.valueOf(rowIndex + 1);
			public int indexOfRowObject(Object rowObject) {
				return 0;
        rowDataLayer.setDefaultColumnWidth(20);
        ViewportLayer rowViewport = new ViewportLayer(rowDataLayer);
        RowHeaderLayer scrollableRowHeaderLayer = new RowHeaderLayer(rowViewport, viewportLayer, selectionLayer);
        RowHeaderLayer rowHeaderLayer =
                new RowHeaderLayer(
                        new DefaultRowHeaderDataLayer(
                                new DefaultRowHeaderDataProvider(bodyDataProvider)),
                        viewportLayer,
                        selectionLayer);
        RowHeaderLayer rowHeaderLayer2 =
                new RowHeaderLayer(
                		rowDataLayer,
                        viewportLayer,
                        selectionLayer);
        ColumnOverrideLabelAccumulator cellOverrideLabelAccumulator =  new ColumnOverrideLabelAccumulator(rowHeaderLayer2);
        rowDataLayer.setConfigLabelAccumulator(cellOverrideLabelAccumulator);
        cellOverrideLabelAccumulator.registerColumnOverrides(0, "CELL_EDITOR_TYPE_CHECKBOX");
//        RowHeaderLayer rowHeaderLayer =
//        		new RowHeaderLayer(
//        				new DefaultRowHeaderDataLayer(
//        						new DefaultRowHeaderDataProvider(bodyDataProvider)),
//        				viewportLayer,
//        				selectionLayer);
        CompositeLayer compositeLayer = new CompositeLayer(2, 1);
        compositeLayer.setChildLayer(GridRegion.ROW_HEADER, rowHeaderLayer, 0, 0);
        compositeLayer.setChildLayer(GridRegion.ROW_HEADER, rowHeaderLayer2, 1, 0);
        // build the column header layer
        IDataProvider columnHeaderDataProvider =
                new DefaultColumnHeaderDataProvider(propertyNames, propertyToLabelMap);
        final DataLayer columnHeaderDataLayer =
                new DefaultColumnHeaderDataLayer(columnHeaderDataProvider);
        final AbstractLayer columnHeaderLayer =
                new ColumnHeaderLayer(columnHeaderDataLayer, viewportLayer, selectionLayer);
        // build the corner layer
        IDataProvider cornerDataProvider =
                new DefaultCornerDataProvider(columnHeaderDataProvider, rowDataLayer.getDataProvider());
        DataLayer cornerDataLayer =
                new DataLayer(cornerDataProvider);
        final ILayer cornerLayer =
                new CornerLayer(cornerDataLayer, compositeLayer, columnHeaderLayer);
        GridLayer gridLayer = new GridLayer(
                viewportLayer, columnHeaderLayer, compositeLayer, cornerLayer);
        // MULTI-VIEWPORT-CONFIGURATION
        // use a cell layer painter that is configured for left clipping
        // this ensures that the rendering works correctly for split
        // viewports
        selectionLayer.setLayerPainter(new SelectionLayerPainter(true, false));
        columnHeaderLayer.setLayerPainter(new CellLayerPainter(true, false));
        // as the CompositeLayer is setting a IClientAreaProvider for the
        // composition we need to set a special ClientAreaAdapter after the
        // creation of the CompositeLayer to support split viewports
        int leftWidth = 100;
        ClientAreaAdapter leftClientAreaAdapter =
                new ClientAreaAdapter(rowViewport.getClientAreaProvider());
        leftClientAreaAdapter.setWidth(leftWidth);
        rowViewport.setClientAreaProvider(leftClientAreaAdapter);
        // Wrap NatTable in composite so we can slap on the external horizontal
        // sliders
        Composite composite = new Composite(parent, SWT.NONE);
        GridLayout gridLayout = new GridLayout(1, false);
        gridLayout.marginHeight = 0;
        gridLayout.marginWidth = 0;
        gridLayout.horizontalSpacing = 0;
        gridLayout.verticalSpacing = 0;
        composite.setLayout(gridLayout);
        NatTable natTable = new NatTable(composite, gridLayer, false);
        GridData gridData = new GridData();
        gridData.horizontalAlignment = GridData.FILL;
        gridData.verticalAlignment = GridData.FILL;
        gridData.grabExcessHorizontalSpace = true;
        gridData.grabExcessVerticalSpace = true;
        natTable.setLayoutData(gridData);
        createSplitSliders(composite, rowViewport, rowHeaderLayer.getWidth(), viewportLayer);
        // add an IOverlayPainter to render the split viewport border
        natTable.addOverlayPainter(new IOverlayPainter() {
            public void paintOverlay(GC gc, ILayer layer) {
                Color beforeColor = gc.getForeground();
                gc.setForeground(GUIHelper.COLOR_GRAY);
                int viewportBorderX = compositeLayer.getWidth() - 1;
                gc.drawLine(viewportBorderX, 0, viewportBorderX, layer.getHeight() - 1);
                gc.setForeground(beforeColor);
        // Mouse move - Show resize cursor
//        natTable.getUiBindingRegistry().registerFirstMouseMoveBinding(
//                new ClientAreaResizeMatcher(compositeLayer),
//                new VerticalResizeCursorAction());
        natTable.getUiBindingRegistry().registerFirstMouseDragMode(
                new ClientAreaResizeDragMode(compositeLayer, rowDataLayer, leftClientAreaAdapter, rowViewport, viewportLayer));
        natTable.addConfiguration(new DefaultNatTableStyleConfiguration());
        natTable.addConfiguration(new AbstractRegistryConfiguration(){
			public void configureRegistry(IConfigRegistry configRegistry) {
				configRegistry.registerConfigAttribute(
		                CellConfigAttributes.CELL_PAINTER, new CheckBoxPainter(),
		                DisplayMode.NORMAL, "CELL_EDITOR_TYPE_CHECKBOX");
		                EditConfigAttributes.CELL_EDITOR, new CheckBoxCellEditor(),
		                EditConfigAttributes.CELL_EDITABLE_RULE,
		                IEditableRule.ALWAYS_EDITABLE, DisplayMode.EDIT,
        natTable.configure();
        return natTable;
    private void createSplitSliders(
            Composite natTableParent, final ViewportLayer left, int fixedHeaderWidth, final ViewportLayer right) {
        Composite sliderComposite = new Composite(natTableParent, SWT.NONE);
        gridData.grabExcessVerticalSpace = false;
        gridData.heightHint = 17;
        sliderComposite.setLayoutData(gridData);
        GridLayout gridLayout = new GridLayout(2, false);
        sliderComposite.setLayout(gridLayout);
        // Slider Left
        // Need a composite here to set preferred size because Slider can't be
        // subclassed.
        Composite sliderLeftComposite = new Composite(sliderComposite, SWT.NONE) {
            public Point computeSize(int wHint, int hHint, boolean changed) {
                int width = ((ClientAreaAdapter) left.getClientAreaProvider()).getWidth() + fixedHeaderWidth;
                return new Point(width, 17);
        sliderLeftComposite.setLayout(new FillLayout());
        gridData.horizontalAlignment = GridData.BEGINNING;
        gridData.verticalAlignment = GridData.BEGINNING;
        sliderLeftComposite.setLayoutData(gridData);
        Slider sliderLeft = new Slider(sliderLeftComposite, SWT.HORIZONTAL);
        sliderLeft.setLayoutData(gridData);
        left.setHorizontalScroller(new SliderScroller(sliderLeft));
        // Slider Right
        Slider sliderRight = new Slider(sliderComposite, SWT.HORIZONTAL);
        sliderRight.setLayoutData(gridData);
        right.setHorizontalScroller(new SliderScroller(sliderRight));
    class ClientAreaResizeMatcher extends MouseEventMatcher {
        ILayer rowHeaderLayer;
        public ClientAreaResizeMatcher(ILayer rowHeaderLayer) {
            this.rowHeaderLayer = rowHeaderLayer;
        public boolean matches(NatTable natTable, MouseEvent event, LabelStack regionLabels) {
            if (regionLabels != null && regionLabels.hasLabel(GridRegion.COLUMN_HEADER)
                    && (event.x > this.rowHeaderLayer.getWidth() - 5 && event.x < this.rowHeaderLayer.getWidth() + 5)) {
                return true;
            return false;
    class ClientAreaResizeDragMode implements IDragMode {
        ILayer baseLayer;
        ClientAreaAdapter clientAreaAdapter;
        ViewportLayer[] viewportLayer;
        int diff = 0;
        public ClientAreaResizeDragMode(ILayer resizable, ILayer baseLayer,
                ClientAreaAdapter clientAreaAdapter, ViewportLayer... viewportLayer) {
            this.baseLayer = baseLayer;
            this.clientAreaAdapter = clientAreaAdapter;
            this.viewportLayer = viewportLayer;
            this.diff = resizable.getWidth() - clientAreaAdapter.getWidth();
        public void mouseDown(NatTable natTable, MouseEvent event) {}
        public void mouseMove(NatTable natTable, MouseEvent event) {
            // TODO overlay support
        public void mouseUp(NatTable natTable, MouseEvent event) {
            int newWidth = event.x - this.diff;
            if (newWidth < 0) {
                newWidth = 1;
            } else if (newWidth > this.baseLayer.getWidth()) {
                newWidth = this.baseLayer.getWidth();
            this.clientAreaAdapter.setWidth(newWidth);
            for (ViewportLayer vp : this.viewportLayer) {
                vp.invalidateHorizontalStructure();
                vp.doCommand(new RecalculateScrollBarsCommand());
            natTable.redraw();
            natTable.getParent().layout(true, true);
Re: Add new row header [message #1773660 is a reply to message #1773656] Mon, 02 October 2017 14:02 Go to previous messageGo to next message
You need to enable editing in the row header region aswell.
Re: Add new row header [message #1773663 is a reply to message #1773660] Mon, 02 October 2017 14:22 Go to previous messageGo to next message
Thank you. but How can be do this.?
Is below code enough?
Re: Add new row header [message #1773677 is a reply to message #1773663] Mon, 02 October 2017 17:00 Go to previous messageGo to next message
No, you also need to register an editor and the necessary bindings for the row header. Have a look at the DefaultEditBindings to get an idea.
Re: Add new row header [message #1773685 is a reply to message #1773677] Mon, 02 October 2017 21:33 Go to previous messageGo to next message
I can add checkbox and can be checked and unchecked. But checkbox image is not updated correctly. May you run example code.(If it is possible) You can see problem.
The code is below. Thank you for your response
import java.util.ArrayList;
import org.eclipse.nebula.widgets.nattable.data.convert.DefaultBooleanDisplayConverter;
import org.eclipse.nebula.widgets.nattable.edit.action.MouseEditAction;
import org.eclipse.nebula.widgets.nattable.edit.config.DefaultEditBindings;
                new ListDataProvider<>(PersonService.getPersons(1), columnPropertyAccessor);
        	Boolean checked=new Boolean(false);
            	System.out.println("set data "+newValue);
            	checked = (Boolean) newValue;
            	System.out.println("getDataValue "+checked);
            	return checked;
                return 1;
				return null;//;Integer.valueOf(rowIndex + 1);
				return 0;
                new RowHeaderLayer(
                        viewportLayer,
                        selectionLayer);
                new RowHeaderLayer(
                		rowDataLayer,
                        viewportLayer,
                        selectionLayer);
        // viewports
        // sliders
			private CheckBoxPainter checkBoxPainter;
				checkBoxPainter = new CheckBoxPainter();
		                IEditableRule.ALWAYS_EDITABLE, DisplayMode.NORMAL,
			                DisplayMode.EDIT, "CELL_EDITOR_TYPE_CHECKBOX");
		                CellConfigAttributes.CELL_PAINTER, checkBoxPainter,
		                CellConfigAttributes.DISPLAY_CONVERTER,
		                new DefaultBooleanDisplayConverter(),
		                DisplayMode.NORMAL,
			public void configureUiBindings(UiBindingRegistry uiBindingRegistry) {
				uiBindingRegistry.registerFirstSingleClickBinding(
		                new CellPainterMouseEventMatcher(GridRegion.ROW_HEADER,
		                        MouseEventMatcher.LEFT_BUTTON, checkBoxPainter),
		                new MouseEditAction());
				super.configureUiBindings(uiBindingRegistry);
        return natTable;
                return true;
            return false;
Re: Add new row header [message #1773693 is a reply to message #1773685] Tue, 03 October 2017 06:19 Go to previous message
Sorry but no. I think you are using the wrong approach for your composition. Much too complicated as you don't need multiple viewports. And I don't have the time to check unnecessary complicated code.
Previous Topic:GroupBySummary Update Parent Summary value
Next Topic:SizeConfig doesd not invalidate cache when DPI converter is set
Current Time: Fri Feb 21 13:55:59 GMT 2020
Powered by FUDForum. Page generated in 0.02459 seconds
