Re: Eclipse Scout 7.0.100 (Oxygen.1) now available [message #1777609 is a reply to message #1773910] |
Thu, 30 November 2017 17:40 |
Michel R Messages: 46 Registered: April 2015 |
Member |
I was with version 6.0.
I am trying to upgrade. I read the migration guides from 6.0.x to 6.1, and from 6.1 to 7.0. I use the "latest stable" version, 7.0.100.017_Oxygen_1.
However, I find that most of the java API changes are not mentioned. Some AbstractTableFieldData becomes (apparently?) AbstractTableFieldBeanData, AbstractDesktop.setOutlines now doesn't accept an IOutline (which is what I get from getAvailableOutlines()) but there is setOutlineInternal(IOutline) : maybe I should use it instead, some constants changed their owning class, etc.
Edit: Ok for ITableRaw I found it on the migration guide, I was probably absent minded in this one.
Am I missing something or is it a work in progress ?
Thanks.
[Updated on: Thu, 30 November 2017 18:03] Report message to a moderator
FUDForum. Page generated in 0.03501 seconds
