Mosquitto service keeps stopping [message #1773254] |
Mon, 25 September 2017 15:33 |
alex kelly Messages: 1 Registered: September 2017 |
I've installed Mosquitto on debian and the service keeps stopping. How do i find out why it keeps stopping? Any help is appreciated. I start it again by running mosquitto -d and it OK for a while but then stops again.
I have a bunch of files in log_dest file /var/log/mosquitto:
-rw-r--r-- 1 mosquitto mosquitto 1.2K Sep 25 15:52 mosquitto.log
-rw-r--r-- 1 mosquitto mosquitto 475K Sep 18 23:47 mosquitto.log.1.gz
-rw-r--r-- 1 mosquitto mosquitto 743K Sep 18 00:06 mosquitto.log.2.gz
-rw-r--r-- 1 mosquitto mosquitto 746K Sep 17 00:10 mosquitto.log.3.gz
-rw-r--r-- 1 mosquitto mosquitto 398K Sep 16 00:06 mosquitto.log.4.gz
-rw-r--r-- 1 mosquitto mosquitto 85K Aug 25 23:58 mosquitto.log.5.gz
-rw-r--r-- 1 mosquitto mosquitto 45K Aug 24 23:57 mosquitto.log.6.gz
Mosquitto.log has the following contents :
1505776658: Saving in-memory database to /var/lib/mosquitto/mosquitto.db.
1505778459: Saving in-memory database to /var/lib/mosquitto/mosquitto.db.
1505780260: Saving in-memory database to /var/lib/mosquitto/mosquitto.db.
1505782061: Saving in-memory database to /var/lib/mosquitto/mosquitto.db.
1505783862: Saving in-memory database to /var/lib/mosquitto/mosquitto.db.
1505785663: Saving in-memory database to /var/lib/mosquitto/mosquitto.db.
1505787464: Saving in-memory database to /var/lib/mosquitto/mosquitto.db.
1505789265: Saving in-memory database to /var/lib/mosquitto/mosquitto.db.
1505791066: Saving in-memory database to /var/lib/mosquitto/mosquitto.db.
1506345775: mosquitto version 1.4.10 (build date Mon, 29 May 2017 13:43:29 +010$
1506345775: Config loaded from /etc/mosquitto/mosquitto.conf.
1506345775: Opening ipv4 listen socket on port 1883.
1506345775: Opening ipv6 listen socket on port 1883.
1506347576: Saving in-memory database to /var/lib/mosquitto/mosquitto.db.
1506349377: Saving in-memory database to /var/lib/mosquitto/mosquitto.db.
1506351178: Saving in-memory database to /var/lib/mosquitto/mosquitto.db.
1506352979: Saving in-memory database to /var/lib/mosquitto/mosquitto.db.
FUDForum. Page generated in 0.02714 seconds
