Home » Modeling » EMF Parsley » Creating a EMF Parsley standalone application (How to create a standalone EMF Parsley application)
Creating a EMF Parsley standalone application [message #1773181] Fri, 22 September 2017 21:45 Go to next message
Satish Rajanna is currently offline Satish RajannaFriend
I have an EMF Model. I am able to create an EMF Parsley project. However I am unable to create a standalone project that launches without the eclipse editor.
I tried configuring the Application and Perspective in the plugin extension points. However I was not successful. I have problems launching the mail example EMF Parsley project too.
Re: Creating a EMF Parsley standalone application [message #1773252 is a reply to message #1773181] Mon, 25 September 2017 15:06 Go to previous messageGo to next message
Vincenzo Caselli is currently offline Vincenzo CaselliFriend
Hi Satish,
let me ask you some more details on this issue.
Which version of Eclipse are you using? (Mars, Neon, Oxygen)
Which version of EMF Parsley ?
What errors are you getting when launching Parsley Mail Example and your application?
Thank you
Vincenzo
Re: Creating a EMF Parsley standalone application [message #1773349 is a reply to message #1773252] Tue, 26 September 2017 15:31 Go to previous messageGo to next message
Hi Vincenzo,
I am using eclipes Oxygen, and EMF Parsley - 1.2.0.v20170609-0953.
When I tried launching the application, I get unresolved dependencies error. But I was able to overcome this by selecting all required plug-ins from the Run Configuration.
However now I am stuck with other problem. I tried developing a pure e4 application. I was able to export the application. Launching the application caused an exception :
ENTRY org.eclipse.equinox.common 4 0 2017-09-26 11:29:33.151
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.equinox.common [49]
Unresolved requirement: Require-Capability: osgi.ee; filter:="(&(osgi.ee=JavaSE)(version=1.8))"
This exception occurs even for a test (nothing to do with EMF Parsley) e4 application.
Thanking you
Satish
Re: Creating a EMF Parsley standalone application [message #1773371 is a reply to message #1773349] Tue, 26 September 2017 21:45 Go to previous message
Hi Satish,
version 1.2.0.v20170609-0953 has indeed a dependency problem.
Could you try updating EMF Parsley to version 1.2.1 with the following update site:
http://download.eclipse.org/emf-parsley/updates/1.2/
? (this should update to version 1.2.1.v20170625-1309)
Previous Topic:Tutorial on how to build web applications with EMF Parsley
Next Topic:Oxygen with coming xtext 2.13
Current Time: Sat Sep 26 06:23:45 GMT 2020
Powered by FUDForum. Page generated in 0.02097 seconds
