Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Dynamic creation of EObject(I am missing something wrt EPackages)
Dynamic creation of EObject [message #1773030] Wed, 20 September 2017 08:25 Go to next message
I found this bit of code on SO on how to create an EObject programatically:
EClass eClass = EcoreFactory.eINSTANCE.createEClass();
eClass.setName("Interaction1");
eClass.setInterface(true);
EObject obj = EcoreUtil.create(eClass);
When run it throws an NPE because EClass dosen't have a package. From EcoreUtil:
  public static EObject create(EClass eClass)
    return eClass.getEPackage().getEFactoryInstance().create(eClass);
There is in EClass getEPackage() but no setter.
How does the package get set?
btw,
The class I am trying to instantiate is generated and on the classpath.
Re: Dynamic creation of EObject [message #1773035 is a reply to message #1773030] Wed, 20 September 2017 10:27 Go to previous message
about the way to set the EPackage this is because you must set the reference the other way round: create the EPackage
EPackage pack = EcoreFactory.eINSTANCE.createEPackage();
pack.setName("something');
pack.setNsURI("something');
then use the .getEClassifiers().add()
pack.getEClassifiers().add(eClass);
However, except if this is on purpose (for example if you want to create both the metamodel and model completely dynamically), I think you should not try to recreate you metamodel in order to instantiate model elements.
You should probably consider retrieving the package in the registry,
EPackage.Registry.INSTANCE.getEPackage(YourMetamodelPackage.eNS_URI)
then find you class in the package (navigate in the Eclassifiers and search the one with the expectec name) and instanciate it.
a look to the ecore diagram may help ;-) http://download.eclipse.org/modeling/emf/emf/javadoc/2.9.0/org/eclipse/emf/ecore/doc-files/EcoreRelations.gif
Previous Topic:Edapt sych on Ecore editor
Next Topic:[EMF Forms] Editing optional domain elements
Current Time: Sun Nov 02 16:28:06 EST 2025
Powered by FUDForum. Page generated in 0.04247 seconds
