Re: Papyrus files extension [message #1772820 is a reply to message #1772818] |
Fri, 15 September 2017 16:55 |
Hi Ismael,
I'm not sure what you are trying to do, but the "di" file is not a diagram file. All diagram information is stored in the "notation" file.
The "di" file is there to act as a container for the other two ("notation" and "UML") and to hold the architectural context of the model (e.g., SysML).
/Charles Rivet
Re: Papyrus files extension [message #1772870 is a reply to message #1772820] |
Mon, 18 September 2017 07:12 |
Ismael Soulama Messages: 39 Registered: November 2016 |
Member |
Hi Charles,
I'm trying to extend the papyrus editor. I have a custom model, and I want it to be recognize directly by the file extension.
For the diagram, I keep notation and uml files. As you explain, I juste want to modify the "di" extension. Change it to ".my" by exemple, and keep editing as usual.
It seams too complicated, because all services are link on the diModel, and all architectural context too.
So, is there a way to use all services (create diagram, editing diagram, save diagram, ...) programmatically, by just replacing the di --> my ?
FUDForum. Page generated in 0.02458 seconds
