Home » Eclipse Projects » SWTBot » Open SWTBot test Recorder with RCP application(SWTBot test Recorder + RCP application doesn't work)
Open SWTBot test Recorder with RCP application [message #1772722] Thu, 14 September 2017 11:10 Go to next message
Antoine Omnès is currently offline Antoine OmnèsFriend
I need your help to use SWTBot Test Recorder with a Eclipse RCP application.
I don't know how to start my RCP application with SWTBot Recorder.
File > New > Other > Run Test Recorder > Run Test Recorder on another application RCP
Configuration:
VM:
-Dorg.eclipse.swtbot.generator.enable=true
Run a product: My app.
Apply.
Run.
===> My application start without SWTBot Test Recorder.
Thanks.
Antoine
PS1: I have already seen this Topic
"https://www.eclipse.org/forums/index.php?t=msg&th=1078197&goto=1734430&#msg_1734430" and It doesn't work for me.
PS2: I can use SWTBot Recorder on Eclipse IDE without any problem.
Re: Open SWTBot test Recorder with RCP application [message #1810488 is a reply to message #1772722] Mon, 12 August 2019 16:37 Go to previous messageGo to next message
Andrea Black is currently offline Andrea BlackFriend
Hi Antoine. I know it is almost two years later, but I have the exact same problem. Were you able to get the generator to pop up when you run it with your app? Like you, I an run the generator with the Eclipse IDE, but not with my application which was an Eclipse 4 "product". However, I created a sample Eclipse 3 "application" (not product) and it worked just fine. I wonder if anyone has gotten this to work with a "product"?
[Updated on: Mon, 12 August 2019 23:59]
Report message to a moderator
Re: Open SWTBot test Recorder with RCP application [message #1814803 is a reply to message #1810488] Wed, 18 September 2019 17:31 Go to previous messageGo to next message
To answer my own question, I gave up in running the generator with a product. The workaround is to launch SWTBot programmatically from within the application under test, which is not ideal.
Re: Open SWTBot test Recorder with RCP application [message #1817445 is a reply to message #1814803] Fri, 22 November 2019 09:50 Go to previous message
Ralf Heydenreich is currently offline Ralf HeydenreichFriend
Hi all,
I've the same problem. The crazy thing is that it works with an Eclipse 3 application, but not with a new Eclipse 4 one. Don't know if it has to do with that.
Ralf.
UPDATE: I've checked it with an E3 and a native E4 application. In E3, the recorder is started, in E4 not.
[Updated on: Mon, 02 December 2019 09:42]
Previous Topic:How to press shortcuts containing numpad keys?
Next Topic:popup menu in NatTable could'nt be found
Current Time: Tue Nov 30 07:00:24 GMT 2021
Powered by FUDForum. Page generated in 0.02300 seconds
